arcorob
- Dec 22, 2013
Oh okay...very good to know....I thought I had a way to try the 7 or 8 12AU7's I have...oh well...time to start trying a new tube line...LOL
I just purchased a 6922 jan sylvania tube and am quite disappointed. I cannot notice any improvement at all, actually, the new tube sounds worse than the original 6922EH. How real is time burn in/will this get better with time? I see nothing visually wrong with the tube, but I am new to this.
Should the Jan be an obvious improvement?
TELEFUNKEN,SIEMENS,VALVO,LORENZ, and other German made NOS: These tubes are usually characterized by an impressive open "air" at the top end. The soundstage is large, even in mono applications these tubes have a great 3-D image. The midrange is ruler flat, and the bass is tight and accurate. These tubes have a fine sense of dynamics, and most areimpressively quiet. These arenot "warm" tubes, and to some ears their lack of midrange warmth may be heard as bright. I tend to think of them as accurate, and their clean, focused sonic image is astonishing. My personal favorites. The top types are as would be expected: the 7308/E188CC, the Cca, and the 6922/E88CC. The Cca is a very special 6922 made for the German government for telecommunications. They are excellent tubes, as good as any 7308.Dec 23, 2013 at 7:42 PM Post #3,619 of 8,309 CoiL
Member of the Trade: Wood Audio Accessories & Modifications
O_o That`s really weird that you can`t notice any improvement and find it even worse! ;S Green label JAN Sylvania 6922 should definitely be improvement over 6922EH ! First difference you should notice is better & more "foward" mids section + tighter bass. Soundstage is more or less same. Is this your first NOS tube? If you haven`t done analytical comparing before then maybe your ears aren`t used to finding differences. Also, what headphones are you using?
Btw, there are different label Sylvania`s, are you sure you got Green label JAN Sylvania 6922? Maybe yours is later production (worse sounding?) or it has reached to it`s "end of life"?
My tube is labeled like this: http://www.ebay.co.uk/itm/6922-Sylvania-Electronic-Tubes-/251024184077?pt=LH_DefaultDomain_0&hash=item3a7235130d
Except my tube has different number: 322 and next to it is EAD and there is also vertical number 7002 near the right side of labeling.Dec 23, 2013 at 8:27 PM Post #3,620 of 8,309 andreaburlizzi
- Dec 21, 2013
with amperex orange globe the sound of sennheiser hd 650 is good? i see that is a good combination for rock music, but i don't know if aune t1 is enough... hd 600 can be driven better?Dec 23, 2013 at 8:43 PM Post #3,621 of 8,309 spacequeen7
HD 600 and 650 weaknesses ;
WEAKNESSES LACKS DETAIL: The HD600 has a very smooth sound that can sometimes feel slow and slightly blurred. The HD600 is not the last word in terms of detail retrieval.
TOO SMOOTH: The HD650 can sometimes sound suffocated in its own warmth. It can sometimes sound as though it is attempting to lull you to sleep.
TREBLE:....
so I would look for a tube that can help you in that department..just my 2cDec 23, 2013 at 8:56 PM Post #3,622 of 8,309 andreaburlizzi
- Dec 21, 2013
and with a different tube hd 600 can be driven better than hd 650?Dec 23, 2013 at 9:39 PM Post #3,623 of 8,309 spacequeen7
if you mean louder/more aggressive look for 6N23P-EV (EB) Reflector 1986 and older (double support type )
http://www.ebay.com/itm/200988005021?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
or Rocket but your sound stage will suffer a bit ,I really like what this tube have to offer ,pretty good bang for your buck
http://www.ebay.com/itm/310792543321?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649Dec 23, 2013 at 9:46 PM Post #3,624 of 8,309 arcorob
- Dec 22, 2013
I thought the same things .Two came to mind
1) Needs burn in
2) Forgery ?
3) Bad tube ?
Okay that's three...but those are pretty steady tubes.Dec 23, 2013 at 9:48 PM Post #3,625 of 8,309 andreaburlizzi
- Dec 21, 2013
Thanks for the tube, but i will take it in a second time... Now i'm trying to understand which headphone il better for aune t1,and my doubt was about sennheiser hd 600 or hd 650... I have read that the second il good for rock, but i don't know il aune t1 can drive them, in case i will buy hd600.Dec 23, 2013 at 11:38 PM Post #3,626 of 8,309 arcorob
- Dec 22, 2013
well folks, my T1 is in the house, up and running and burning in as we speak.
I have to say I am impressed. Not a huge OVERWHELMING bang but I never expected that considering my source is primarily XBOX Music downloads. what I did notice
wider, more holographic soundstage
The vocalist is nicely forward and I can literally hear them close to the mic (I cant describe it but it is better)
It can be a bit on the bright side but I think that can be attributed to the tube, burn-in, etc. Not overly but a tad. We WILL remedy that..LOL
So in my opinion, I think I gained 5 to 10%. Doesn't sound like a lot? It is huge. In the audiophile world, you can spend hundreds to thousands to get a 2% increase. For $159 to get even a 5% better in an already tuned system is awesome.![]()
I used the supplied USB (seemed decent but may upgrade) and connected to my system using XLO HT Pro cables (no I did not spend $200 on them, they were a GIFT !!!)
Thank you all...now on to some basic tube rolling (damn..why couldn't they make it work with 12AU7's ..lol)
Dec 23, 2013 at 11:48 PM Post #3,627 of 8,309 slovetro
- Dec 5, 2013
I'm using hd650s and this is my first time comparing tubes. I definitely am not used to comparing differences, but thought I would at least notice a few differences and definitely thought I would prefer the new tube, but I find myself wanting to put the old tube back in. I will use it for a week and see if the sound improves.Dec 23, 2013 at 11:51 PM Post #3,628 of 8,309 slovetro
- Dec 5, 2013
Also, the tube is exactly the one you posted Coil.Dec 24, 2013 at 12:53 AM Post #3,629 of 8,309 Tristan944
- Apr 17, 2012
Arcorob, I have a bunch of questions for you:
1. What is that big amp?
2. What program are you using on that tablet?
3. What headphones?
4. Did you get the Aune T1 on the $109?Dec 24, 2013 at 1:52 AM Post #3,630 of 8,309 arcorob
- Dec 22, 2013
3. What headphones?
The big amp is a Velleman K4040 Tube power amp - 1 12AU7 phase spliter tube , 2 12AX7 input tubes, 8 6L6GC power tubes - 90wpc - All NOS early 60 tubes !
I am running Windows 8.1 with XBOX music pass for streaming
Senns HD280 Pro
No, wish I could have paid $109...paid $159 shipped via Amazon
Other notes - I am using a Marantz SR4023 as the pre and I have and have had multiple turntables (I am a vinyl nut) ..I have even built my own record cleaning machine
I use Polk Monitor 70 II's with a Polk sub . My main table is a ClearAudio Concept with Concept MC cart and a Phonomena II phono stage
I am a tube nut ! So the T1 really spoke to me...If you like tubes, this picture is my garage amp. I built a ss preamp from a kit ($22) built a box, attached it to an early 60's Motorola console amp, added some VU meters and have a little system....It sounds sweet !
Total: 9 (members: 0, guests: 9)
