Deicide3
- May 2, 2012
133 pages
133 pages
And tubedampers actually works, only a little bit, but they`re tightening up the bass a bit. Enough to notice it at least.
Sorry but that "tightening up the bass a bit" must be pseudo-thingy! Dube-dampers for tighter bass? Sorry but imho this is nonsense!
I'm thinking expectation bias...![]()
Actually like speaker spikes/cones, there is every little possibility dampeners will have an effect on the sound.. Physically they cut down on the vibrations and create isolations that ever so slightly..
Can't help you with the Mac portion, strictly PC user here. Once it's on, it's on. But you can bypass the amp using the line out. You can use it dac only, amp only, or dac & amp. Keep in mind that you must use the dac portion if you intend to use the tube as they're tied together. Amp is just a SS amp module that bolts onto the tube dac.2) I am thinking of using the analog output of the Aune to act as a DAC for a pair of speakers, perhaps the Audioengine A2s. Is it possible to use it as a DAC only system, without the amp. Or can the amp still be on, I am not sure how all this works exactly. Please explain.
Thank you.![]()
