I was just checking around to see what people were saying about this amp, as it looks interesting.
LOL. That's not getting real, that's just fantasy. Sorry, it has to be said. There's only so much possible at any price point, due to parts costs, and unless you're doing direct sales almost entirely, it's going to be even harder, especially if you are paying for a fancy, custom chassis. What is more, these manufacturers are always fighting for who has the best SINAD scores, and where they can't simply cheat by only reporting A-weighted 1kHz results, they set the balanced output to 5V, which gives the optimum numbers for the APX-555. They also have large amounts of negative feedback in the circuit to get the THD down, resulting in that "flat" soundstage these designs tend to have.
However, to their credit, they seem have a linear PSU (there's no such thing as a "linear transformer" as stated on the page for the amp), which is likely going to be better than the cheap switching PSUs Topping uses, which require noise filtering to be useful, and the unit isn't likely to die after a few years when the PSU fails.
The stated maximum output is clearly not going to be Class-A. They only list something like 200 mA of class-A output from the transistors. A 2W actual Class A amp in the form of the Mjolnir puts out a HUGE amount of heat, and the S17 just doesn't have the surface area to do 7W. That 7W figure is going to be Class AB, and may not even be RMS, which, if so, means that they are cheating the numbers.
Still, it looks like it might be quite decent. I'd like to see THD vs. output to see what its actual power output looks like though. The $500-1000 price point is the point above which the Law of Diminishing Returns kicks in for DACs and amps.
Let's gear real here. By all accounts this amp a bargain in terms of sound quality, and it is likely to be spreading panic among competitors.
