Majuto
I guess in some listings 6se is harder to drive than Raal Ca-1a, anyhow Raal needs usually vol 56 with Aune. Propably this is a current/voltage thing again.43 mostly, 47 on some bass only tracks.
Peaks at 92 db for my test tracks means programme at high 60's-low 80's. I listen softer than anyone I know. what do you think of the CA-1a? I want one but I need a counter to it like an Auteur since its so detail forward.I guess in some listings 6se is harder to drive than Raal Ca-1a, anyhow Raal needs usually vol 56 with Aune. Propably this is a current/voltage thing again.p
[/QUOTE
I like Ca-1a a lot. At first it sounded somehow wild and a tiny bit fatiguing and so I decided to buy Mitch's neutral filters. With these Ca-1a sounded really good from the first minute. A real surprise was after about three weeks how good they sounded also without filters. A long "getting used to period". Ca-1a also feels very comfortable, also it looks refreshingly different.
Would I be correct to read this as you listen mostly in the 60's to the low 80's and peak at 92 Db's?Peaks at 92 db for my test tracks means programme at high 60's-low 80's. I listen softer than anyone I know. what do you think of the CA-1a? I want one but I need a counter to it like an Auteur since its so detail forward.
No you have it right.. My circle these days is pretty small - 6 - and one fellow is close, and he's an acoustic musician. I'm 67.5 yrs old, I need a bit more now than 20 yrs ago.Would I be correct to read this as you listen mostly in the 60's to the low 80's and peak at 92 Db's?
For listening to music?
If that is the case, I listen at MUCH lower levels than you.
Or have I misunderstood your post?
Wow! I am just about 64 and my ears get sensitive at anything above 75Db's. And that is the peaks.No you have it right.. My circle these days is pretty small - 6 - and one fellow is close, and he's an acoustic musician. I'm 67.5 yrs old, I need a bit more now than 20 yrs ago.
Great definition of Ca-1a bass. With the basic Raal cable it's punchy, but the bass articulation and overall quality could be better. To hopefully make bass more articulate and a bit tighter I decided to order Star 8 mkii silver cable. We'll see how it works.I like the CA-1a - more w/ filters. The time I heard w/ the filters was with a Pass Int-25, a DAVE, and DSD256 & 512 files. I've had an ear for ribbon tweeters for 40+ years, so there isn't much to get used to - besides ribbons vs quasi ribbons (I.E. planar magnetics) in the bass/mids. I've never heard any estat speaker (or high end dome tweets) that can keep up with ribbon tweets (even the Chinese ones) over about 5k. The CA-1a is great down to 250-300 Hz range, but the bass reminds me of a muscle tube amp running a big panel estat vs a top SS amp - there is a tonal discontinuity to my ear in the bass->mids and that means the CA-1a is liable to be doing chamber music and female vocals where that won't be as obvious - or maybe I'll get used to it.
Seems like a lot of them for sale right here - unless people are not updating their sales listings... might be a good time for a used set w/ the adapter. But I don't want to get back into computer based audio, so bye bye filters.
Actually I realize I pull out the SPL meter when I'm testing bass. Just now two hours of my typical music alone and 78 db was the peak but mostly in the high 50's-mid 60's. So about the same. I have no idea how anyone can listen regularly at over 100 db and still have ears capable of discerning quiet details.Would I be correct to read this as you listen mostly in the 60's to the low 80's and peak at 92 Db's?
My ears have their own self-defence system built in. If any of my stuff peaks over 75Db's for a fraction of a second I tend to reach for decibel meter and sure enough I am running high and have to dial it down.Actually I realize I pull out the SPL meter when I'm testing bass. Just now two hours of my typical music alone and 78 db was the peak but mostly in the high 50's-mid 60's. So about the same. I have no idea how anyone can listen regularly at over 100 db and still have ears capable of discerning quiet details.
.... may I interest you in this.... And with a twist of the volume knob, I am back to happy town!![]()
My whole point was that I am a ***** when it comes to decibels. Shane just can't do the loud stuff..... may I interest you in this?:
Temperature update....
Okay, it has been 7 hours 11 minutes. S17 still in 100ma High Gain XLR input and 4 pin XLR output.
Temperature holding steady at 55c with the Room Ambient at 78f (25c). The highest it got was 56c then came back down to 55c.
I am calling this a success. No more temperature issues. If anything changes, I shall let you know... but 55c with a room temperature of 78f (25c) is great in my book.
@Slackaveli the mini cooler link is below for those interested.
Amazon Mini Laptop Cooler URL:
https://www.amazon.com/dp/B07QXJN1RK?ref=ppx_yo2ov_dt_b_product_details&th=1
Because I have my fan plugged into a USB Hub that is always on, I just purchased this USB inline switch to allow me to turn off the fans when I don't need them:
https://a.co/d/4GnZnz8
You are right (in regards to cables from Aliexpress, like Openheart). I previously reported no heat issues in 100mA, but that was in low gain. In high gain the temperature rose to 66 degrees and stabilized. It was highest I've seen so far. That was on the Arya Stealth using a balanced 4.4, 16-core, this one. When I switched to the NDH-30 with the original cable, the temperature dropped to 62 degrees relatively quickly and stayed there. Switching to low gain made no further difference.normal cables. Only I'm afraid because of the dense weaving, they have a high inductance, they will lead to self-excitation of Aune
