Aune M1P
Mar 4, 2024 at 8:18 PM Post #346 of 593
I understand that Bluetooth is not the main function, but the connection problems in the signal transmission mode to another device are so big that this is unacceptable.
I have never seen such a bad connection, even in very cheap devices. The connection lost even when the devices are lying next to each other, there is no distance between them. and when the connection is broken, there is an unpleasant sound. I thought at first that the Bluetooth module might be damaged, but everything works well in receiver mode.
most likely some kind of software error, it would be great if you checked it out and fixed it if possible.
"The connection lost even when the devices are lying next to each other" - That doesn't usually happen, unless there's some compatibility issue. Can you please try another Bluetooth device (headphones, speakers, etc.) and let us know the result?
aune For music we design. Stay updated on aune at their sponsor profile on Head-Fi.
https://www.facebook.com/auneaudioofficial https://twitter.com/auneaudio https://www.instagram.com/auneaudio http://www.auneaudio.com sales@auneaudio.com
Mar 4, 2024 at 8:24 PM Post #347 of 593
Question for Aune,
I am loving the sound quality from the M1P so much that I am now looking for a dac that would give me the same sound signature or quality. Can you recommend a dac from your “S” series preferably with a balanced out? Thanks.
Thanks for liking the M1p so much:) We cannot say exactly the same sound signature but the S9c Pro DAC with headphone amp is definitely a great product that we would recommend http://www.auneaudio.com/Desktop_en/126.html
It's been very well received too, and there are quite a few reviews that you can maybe refer to before you buy one :)
Mar 5, 2024 at 11:58 AM Post #348 of 593
Hi! I could use some advice. I received my M1P last night and played with it a bit (had to use translate to change language to English) and sounded amazing. I put the M1P in my bag with it off but must have hit the power button. Fast forward to this morning and the device won't turn on. I assume if I charge it for a few hours, it should turn back on? Anything else I should do such as a reset?
Mar 5, 2024 at 12:50 PM Post #349 of 593
theres a little reset hole on the right side of the device. try that if charging doesnt do anything
Mar 5, 2024 at 3:36 PM Post #351 of 593
That was weird. I used the reset hole and everything is fine. I wonder why it locked up unless that's a common issue?
what software version are using. I tried the 1.7.5 that aune linked here and my player kept locking up and became very temperamental. it was the first time i had to use that reset button since ive had it.
I've reverted to the 1.7.0 version from aunes website and everything is fine again.
Mar 8, 2024 at 2:36 AM Post #352 of 593
after using my sony a306 for the past few months, i came back to the aune this week. holy crap such a powerful full bodied sound. i just lost myself in some nirvana tracks i havent listened to in years.
also the simplicity of the player. aune nailed it
Mar 9, 2024 at 3:30 PM Post #354 of 593
Is there much sound difference between the 3.5mm and 4.4mm hedaphone out?
No only power output. All 3 phone outs sounds almost identical
Mar 9, 2024 at 3:31 PM Post #355 of 593
Yes, no comparison in sound, I also have A306 (Such a sweet portable player with warm and lush sound) but the M1p is just better in all senses
Mar 11, 2024 at 12:00 PM Post #356 of 593
I have the 1.7 version on their website. It came with that version from the seller.
Mar 11, 2024 at 12:28 PM Post #358 of 593
Has anyone had any luck buying a leather case for their m1p? I've ordered one from HiFiGo and it's taking forever to ship.
Just found this amazing item on AliExpress. Check it out!
£15.69 | AUNE M1P Protective Shell Leather Case for AUNE M1P HiFi Lossless Music Player
https://a.aliexpress.com/_EHAdE41
Be aware that the case needs some alterations to fit large 4.4mm plugs, this is the official case but they just didn't design it properly.
Mar 11, 2024 at 12:34 PM Post #359 of 593
Mar 11, 2024 at 3:44 PM Post #360 of 593
Efficiency all the way.
