T.R.A.N.C.E.
- Mar 24, 2010
Fair enough but if you have a problem with thread priority then you must have a very old pc.
Maybe I'm just paranoid. I'm running an 8 thread i7 clocked at 4.5ghz
^ Interesting, did not know about the output impedance, I don't know if it's accurate or not but it's power is specified at 700mW into 32ohm, which is massive!
Also Noisy Motel did an honorable gesture and gave me $13.50 off a purchase of TMA-1 Ghostly Edition (plus 10% off) to make up for the $15 I could have saved on the M1 I purchased. So thumbs up to Noisy Motel service!
The heat issue does not disappear. Seeing as you have just got one and I have owned mine for a few weeks I thought I should let you k ow - so its still happening after 100hrs + playback! Its a known issue and if you google translate chinESE forums there is a mod that aims to reduce the heat issue. How do find the sound?
hi I have the m1 And hd25-. It drives them well. Only needs a little more than 1/4 turn of vol to be almost too loud. When pushed beyond this I detect no ditortion. Sound is full. Good instrument Sep. Bass is v tight. Mids are forward. I'm comparing it to mzrh1 Sony minidisc and it sounds equally as good.
