Mr.HiAudio
Member of the Trade: RIOBuds
I also prefer just armature headphones better because of the great treble, so I think Audiosense will think about a new modelOkay
They are working on the DT300 and the DT600. The DT300 should be out next month.I also prefer just like armature headphones better because of the great treble, so I think Audiosense will think about a new model
Thanks for the info. But I am very illiterate when it comes to audiophile terms. Do you mind elaborating on those terms such as OI, SE? I understand physics/audio engineering/electronics terms better.Your source is the Fiio M11 right?
Its actually worse on balanced with the M11 + T800 combo. Since the balanced output has 2 OI instead of 1 OI in SE.
(I had the M11 before, so I know this first hand.)
Se = single ended connection. Aka, non balanced.Thanks for the info. But I am very illiterate when it comes to audiophile terms. Do you mind elaborating on those terms such as OI, SE? I understand physics/audio engineering/electronics terms better.
That is very informative. It seems the water of IEM is much deeper than what I initially thought. I guess I need to stop digging, otherwise my wallet will cry.Se = single ended connection. Aka, non balanced.
OI = output impedance, the impedance/resistance of the amp itself.
With ba iems, and especially a sensitive one like the T800, small changes in resistance ( OI + cable resistance) are very likely to cause changes to the FR (frequency response).
For example here is a graph on 2 different resistances with the Campfire Andromeda:
Source: https://www.audiodiscourse.com/2019/06/campfire-andromeda-mini-review.html
Usually you would want as low total resistance as possible. But with BA iems, it can be a bit more tricky since you dont know what the total resistance that the tuner had when they tuned the iem. So if they had a high total resistance, but you yourself uses sources and cables with low resistance, the FR changes might change it for better/worse.
An example that I have experienced is with the Tansio Mirai TSMR 4-pro, it was very likely tuned with a higher resistance in mind. Since changing the stock cable (that measures poorly = high resistance) to a 3rd party cable with a lot lower resistance made the sound very bad.
yeah, if you are already satisfied then stop or your wallet will die lol.That is very informative. It seems the water of IEM is much deeper than what I initially thought. I guess I need to stop digging, otherwise my wallet will cry.
Thank you!
This sage advice seems to not be given nearly enough. There seems to be a universal push for running things “balanced”, assuming it is always better. Not only is it not necessarily better or is unnecessary, but it can be deleterious is certain circumstances.
However, I do realize that things are not always as straightforward as the raw science suggests, and that frequently, the balanced output on an amp may have received more attention in the design process, assuming everyone will use it.
Moondrop Kanas Pro & AQ T800 were my first blind forays into off-label hifi experimentation. Slater made several kind suggestions that were very helpful to me at the time. Haven’t seen him in awhile. I’m sure he doesn’t know me but I got much gratitude for that guy.That is very informative. It seems the water of IEM is much deeper than what I initially thought. I guess I need to stop digging, otherwise my wallet will cry.
Although as you rightly mentioned, most companies prioritise balanced over SE. And, I've too noticed that mostly it's DDs that scale brilliantly with balanced out. Hybrids somehow sound too powerful or get hot in treble at times.Yeah i think u are right that when a DAP or source comes with a single ended and balanced output, frequently the better implementation seems to be done on the balanced port. But I do think a well implemented singled ended output is better than a half baked balanced output any day.
Please make sure of the output impedance of those dongles. If not paired properly T800 sound may drastically change. Usually around 1 ohm output impedance suits it well. I'd say rather buy some usb dac-amp, like shanling up4, fiio btr5, etc.I am considering buying a Bluetooth dongle with my T800. But I am a bit concerned of the MMCX connectors becoming loose after swapping many times. I am wondering if anyone has some experience in this regard. Thanks in advance.
