inthere
- Apr 11, 2012
Pay more than msrp. Problem solved? (not a good solution, but might work out for you)
Exactly what I was thinking, just a bit hard to pull the trigger.
BTW do we have a favorite third party cable that's not @$$ expensive? I sit practically right beside my amp and the crazy long cable keeps getting stepped on or caught under a chair wheel.
I guess that depends on your definition of expensive. I like the Moon Audio Blue Dragon quite a bit more than the stock cable. I got mine used so it wasn't too expensive.
Or getting eaten by evil cats lol
/cut
I'm sorry, but you're wrong. And yes, HD600's are more accurate than NH's, in every single way, no doubt about it. No offense, but anyone who disagrees with that is either deaf or trying to push the NH's forward and make them appear better than they actually are. Your interpretations of song frequency graphs are wrong too. It's not as simple as "flat freq. response = every part of the song sounds equally loud". Actually, that would make a rather bright sounding recording. You're forgetting that what you see on those graphs are raw frequencies in the song, not the actual frequency levels you're hearing. A natural sounding record will often be warm-tiled, in fact, take any of the best (most natural) sounding recordings out there, and you'll see they're always a bit tilted in favor of lows, and they still don't end up sounding too warm on neutral systems. Again, take any realistic sounding recording, and you'll find that to be true. For example, Jazz in the pawnshop is an incredibly natural sounding recording, yet, at all moments, the upper mids and highs are 10-15 db below low mids and bass, yet it doesn't sound dark or muffled. That is because by the time you actually hear the sound, certain frequencies get greatly amplified, others reduced, etc. I don't know what else to add to this, other than you're clearly going too far trying to justify the sound of NH's, which is clearly nowhere near neutral, natural or accurate, not by any standard. It's a warm and thick sounding headphone, and it's the headphones fault, it's not about the recording. I'm not saying it's a bad headphone because of that, but denying it's inaccuracy would be absolutely ridiculous.
I just ordered a Blue Dragon to replace my destroyed original cable. 5 ft long with a 3.5mm Oyaide plug. I have a Black Dragon (HD-700) and a Silver Dragon (HD-650) and I love the build quality.
