syryanyang
- May 22, 2012
Can anyone confirm if I can use the dog pads or alpha pads from mad dogs on the 900x‘s?
^^^they fit on the W1000 and AD2000
The clamping is a bit hard and I feel like the headband isn't even there. If I move my head too much then my AD900X slides off my head. Do I just tie the two wings together?
They fit fine on my head, but that mod looked soooo challenging that I just had to give it a try! Yup, works well!
You'd better be careful, the poster of this mod obviously did not put a lot of thought into it. He mentions that he was too lazy to get a SLR out, there's a good chance you'll be ruining your A900X. YOU WERE WARNED!
I posted up my video of the AD1000X
Thank you, thank you. I've been waiting for this video review and it's just as excellent as the previous ones. You've also sold the AD1000X for me as well. A couple of quick pieces of feedback. I'd like it if you actually wore the cans in your videos for a short amount of time and possibly turned your head to illustrate fit. This would be particularly important with the AD series as those wings don't always jive with people. Onto a question. Compared to something like the AD700, how is the fit of your AD1000X? I ask because I had to do some light modifications to get the AD700 to seal well and was hoping the AD1000X would do a better job of fitting properly. Of course, if you had pics, that would be even better.
Keep up the great video reviews!
