AzraelDarkangel
- Dec 28, 2006
I'm liking the Audeze vegan microsuede pads with my AD1000x. Ungodly comfortable. I'm tempted to try the leather pads to see if it gives me a bump in the lower bass.
How do those pads effect the sound compared to the stock pads?
Hello, everyone.
I just subscribed this thread and started reading previous posts... I just got slightly used pair of ATH-AD2000x and started listening with it. What I immediately noticed are after listening 30 minutes..
[1] I really wish the cable is short and removable. Even though it is not tangling, 10' cable is too long for me since I listen music MBA>Meridian Explorer or Shozy Alien.
[2] This can requires quite a bit of power (40ohm) than I expected. I expected to drive this with low to med level of volume but this can requires similar power as my Ety ER4S (100ohm) to achieve same volume level.
[3] My head size is slightly larger than normal and earsize is relatively small and found that this can is quite comfortable. Wings sit on my upper sides of head tightly so does not come down and my ears are fit 95% inside ear cup (just bottom tip of ear is slightly touching the pad) and did not notice any discomfort. This can is very very light..
[4] I was expected that there is very little bass after reading several reviews but I personally found that mid & upper bass are definitely there but sub-bass is lacking. After playing with EQ a bit to increase sub & mid bass and bass is now slamming my ear. It is not muddy but tight. Not as tight as T50RP MK3 but still Tight.
[5] Female vocal & string instrument sounds great as other reviewers told... I personally found that it sounds very similar to Ety ER4S with bigger sound stage.
So far, very satisfied except the long non removable cable...
Hello, everyone.
Hello, everyone.
Thanks for posting your impressions. How do you find the highs relative to the mid-range?
It seems like the left side of my AD1000x is very slightly quieter than the right side since a few days... Anybody know how that became and how I can fix it?
could be the pads on one side are not as stiff and therefore the distance to the ear could be different causing an imbalance. that happened to my Grado GS1000. Replacing the pads fixed the issue. Try switching the pads around. Does the imbalance move? if so then just replace the pads.
Yeah it was the pads on the left side of my ear being more distant than the right side... The headphones are not defect.
These are AMAZING headphones, they're very underlooked here on head-fi.
overlooked
I just sold mine, wasn't reaching for them much with HD800S and TH-X00 now. Comfort was always a bit of an issue (driver touching ear, itchy pads) and I didn't like the way different pads changed the sound. I do enjoy the sound/flavour though.
