AD2000 Left, AD900 Middle, HP200 Right
Pair of wires to each terminal
Use an X-Acto knife when cutting the glue out.
Although the drivers fit pretty snugly without the solder wrapped around, this makes it pretty tight. I'm able to poke it out with my finger if I push hard enough, but it's enough to secure it in there, and I refuse to glue these drivers in there. Anyone attempting to do this, make sure that the solder does not touch the terminal, or you will short the connection. Oh, and I put some tape around the four sets of holes on the baffle. Without them covered up, the bass sounded flabby - AD2000 drivers suck at producing bass at loud volumes unless you have an air-tight seal in front of the driver. You do that, and you have bass that rivals Planars.
Those holes on the grill look pretty funky, but I have something in mind to cover it up.
The beyer gel pads have to be the best pads ever made. Excellent isolation, comfort, every headphone that I've put these on improve the sound, they don't flake like pleather, and they don't get flat over time like basically every other earpad out there.
Sound-wise, they're pretty much the same as my previously modified headphones, but since the driver is closer to my ears, I'm able to tone down the peaks and dips in my equalizer about 4dB. I think imaging is better too. The modified baffles on my AD2KMKIV introduced some unwanted reflections, and that gave my ears some messed up positioning cues (still better than K7XX lineup, though). There's nothing but driver and ear with these headphones/earpads. Fortunately, these are just as comfortable as my AD2KMKIVs too. The headphone design is much more functional, and I wouldn't be afraid to wear these out in public.
The only downside right now is that the clamping force is on the light side, and I'd like a bit more. But once I start sweating a bit around my ears, the gel pads stick to my skin, making an air-tight seal, and the bass is like it was on my AD2KMKIVs- perfect. I guess I have to cut my hair off to get the seal I want without potentially breaking the headband trying to bend it. The headband is nothing but plastic and padding, and I'm afraid to bend it.
Well, I guess that's it for now. They shall be called the GBH-2000s, hehe. They are basically what I wanted my
GBH-1000s to be way back when.
