davek
- Jan 6, 2011
Guys am considering these headphones, but getting mix reviews in regards to the sound stage. Some people say its pretty wide and others say it has almost none....so what is it?
How does sound stage compare to AD700/900, AD1000/2000X, AKG K702, K712, DT990, Fidelio X2 etc?
As I want these for primarily music and some gaming.
Struggling to decide between this and the AD1000X (can get it the same price).
I am upgrading from an ATH-AD700 (original non-X version).
Hello!
I've had AD700, AD900, AD2000, W1000X, AD900X and now the R70X. In terms of soundstage the AD700 is the deepest, and it's fairly wide too. AD900 is wider but much less deeper. The AD2000 (and I heard the X is more or less the same from this point of view) is very upfront, everything is "in your face", or an even better description: it sounds like there was no headphone, there's no distance between you and the music. Coming from the AD700/900 it was a bit shocking at first but then I get used to it, and liked it in the end very much. The R70X is very close to the AD2000 in terms of soundstage, so it's very upfront as well. You can use some extra stuffing under the back side of the earpad, it will make the soundstage bigger and the sound a bit more lively. I haven't heard the AD1000X but the AD900X was a bit too bright for me, a mild V signature I guess, the R70X is very different. It's not like any other open Audio-technica, ony the airy presentation is what's common with the above models. So if you like the smoother and airy presentation of the AD700, and want a good amount more bass, it's your can, if you want brighter highs and a more agressive sound, go for the AD1000X.
Hope that helps!
