Audio-Technica ATH-R70x - In-Depth Review & Impressions
Jul 26, 2015 at 8:54 PM Post #376 of 2,731
Have you guys tried R70x with Sony PHA 3 and its balanced cable?
I think R70x and Sony balanced cable are compatible.
Both uses dual stereo 3.5mm.
Can anyone try this and tell us how they sound?
I dont see how they are compatible, unless u want to reterminate the 2 headphone side jacks to ath 2.5mm jacks. Then yes they are usable. Or you are saying that make a cable can enables the r70x to be used onto the pha3 which is quite simper to do
Jul 26, 2015 at 9:03 PM Post #377 of 2,731
No, both of them are using two 3.5mm stereo jacks, meaning their connectors are the same.
Can anyone try Sony's balanced dual 3.5 mm cable with R70x??
Jul 31, 2015 at 12:44 AM Post #386 of 2,731
