I haven't heard the K553, but MSR7 doesn't sound thin to me - not at all. Its bass is perhaps just a little low in level relative to the mids and highs, but it sounds full bodied, very tight and deep. I have no problem enjoying the MSR7 with EDM and trance, and will take it over most other headphones with stronger bass for these types of music, because MSR7 has a tighter and more accurate low end than most other headphones.
I will highly recommend the MSR7 at its usual price of $250-$300 as one of the best sounding headphones in that price range, regardless of type. If you can get it for $170, that's a steal, unless there's something wrong with the unit that is.
Where did you get those averages? MSR7 clearly has the worst isolation of the three by a significant amount. If you look at Innerfidelity isolation graphs, you will see that it only isolates well above ~1kHz. At 800 Hz for instance, the MSR7 offer 5 dB of isolation, K550 offers almost 15 dB of isolation, 10 dB higher than MSR7, and HD280 isolates by roughly 20 dB, which is 15 dB higher than MSR7. For real world use, low frequency isolation will make much more of a difference than high frequency isolation. All three do a good job of attenuating the highs, but MSR7 offers almost no isolation up to 800 Hz and only really begins to isolate well from 2 kHz. This means that most of typical city noises, such as traffic, conversations, announcements, etc, will be much louder with MSR7 on than with the other two, especially compared to HD280. To be fair, however, none of them isolate at all below 200 Hz, so for those who want to have a good listening experience on a plane or loud train with lots of low frequency rumble, all three willl be useless and any half decent IEM will isolate far better in those situations.
