iancraig10
- Jan 21, 2005
Yes, the inside of the housing is different. Outside looks fine and in isolation, you might not know until you heard it!!
My guess is that $80 might well turn out to be fakes!!
Yes there are now more matches by my search engines. They are now being released in Japan four days ago. Just takes time for the search engines to update themselves. I am looking for bass emphasized headphones and the one that I tried at RMAF was the beyerdynamic DT 1770 very nice. The problem with bass emphasized headphones is to make the mids clear without bleed. Hard to do. I ran a test with my MSR7 using my IFI Retro amp and with xbass engaged I was getting similar results as my HE-400 using the balanced outputs on the Oppo HA-1 amp. I was playing back Arron Copland: Billy the Kid, gun battle. The bass drum along with the tympani playing at the same time. The trick is to separate the bass drum from the tympani and the MSR7 does well here. I did had the DT1770 on order but canceled it for the time being.
