MrPhilicorda
- Nov 17, 2014
I'd like to keep the sound exactly as it is now, that's the problem with replacing the pads. I actually have a pair of earpads that fit the M40's perfectly, they come from a Asus Vulcan ANC gaming headset. They're exactly the same size as the M40 stock pads, the same thickness, but with a slightly larger hole that go around my ear perfectly, they're made out of infinitely better quality pleather that is super soft and comfortable and they have memory foam inside them. They're basically probably the most comfortable earpads I've ever tried, better than the Beyerdynamic round pads because they have the perfect ratio of very soft memory foam on the top and firm foam on the bottom. The problem is, they mess with the sound too much. They significantly reduce the bass response, make the mids sound shouty and highs piercing. They do exactly the same thing when I put them on a Sennheiser HD438, except the effect is even more pronounced these since those come stock with velour pads and have virtually no seal around the ear. I noticed that the M40 pads have holes on the bottom that allow the foam to breathe, Asus pads don't have that, maybe if I cut out the same holes I'll sort out the problem, but I don't want to ruin the Asus pads and I think I will if I do that, because proper seal is crucial for those headphones. I feel like the Asus pads create a far better seal around my ears than M40 pads, almost a vacuum feeling (which makes sense, since original Asus headphones had active noise cancelling and had to seal very well, breaking the seal just a bit with ANC turned on makes the sound awfully bad), and that simply messes with the sound too much.
What I will actually do is cut out oval pieces of wood that are just slightly bigger than the hole on the M40 pads and then I'll just stuff the wood into the hole, and leave it overnight to stretch the earpads out. I can get about 0,5 cm in each direction like that. I used the same method on several pleather pads before and it worked.
The DT250 ear pads are perforated on the back. While the M40x has a few big holes the DT250 have lots of small holes, but I think they do pretty much the same thing. I must stress that the change is sound is very subtle, and I would find it hard to believe that anyone would think it's for the worse. The strong bass is still there but it just sounds a little more airy and clear in a way that makes it easier the hear what's going on in the bass department. Anyway, good luck with the stretching-project, if it works that's of course the ideal solution to your problem.
