Audio Technica ATH-E70, ATH-E50, ATH-E40 IEMs announced at NAMM 2016
Apr 19, 2016 at 12:56 PM Post #301 of 1,068
  There goes 1 person claims he has problem with fitting, the issue is as I feared the short nozzle... This usually vary case by case though.. so I think demo 1st is a must...
About it not being long though, some folks in IM series did have similar problem with their IM02, some fix it with adding one layer of a cut silicon bore to give extension (?) didn't reply catch what they mean, but you can check that thread for a probable fix.
I hadn't thought of trying to extend the nozzle, but I do have some Comply tips coming in. If the fit is still no good, I am probably sending these back instead of fiddling around, regardless of how good they sound at their current price point.
  You can flip them and try the fit again. L to R and R to L. Raises the tube up higher some and should be tried.
Of course bending the memory wire right helps. You can be surprised that they may go a little deeper.
Don't know your ears but worth a try. I know that I look forward to a cable w/o a memory wire coming along sometime. And a bit shorter as I don't always need 1.6 meters.
Yes, I tried that last night but unfortunately there is no difference for me. I did bend the memory wire to a shape similar to my Epic cables, but I don't see how that would help with the fit issue, as the poor fit mainly stems from the short nozzle/raised nozzle base. For what it's worth, I removed the housing from the cables to see if I could get a good fit with just the housing, and still no go.
Sorry if I'm using any incorrect terminology!
Apr 19, 2016 at 2:12 PM Post #302 of 1,068
Maybe, if you send them back, you can try out the Trinity Phantom Sabre though they won't be shipping till next month sometime. ~$85 right now which is the same price range as the $89 I paid for the E40 and they are also dual-phase drivers and come with both long and short tuning nozzles. Certainly much of the same appeal of the E40 would have.
I went for the pre-order myself as I haven't tried a Trinity phone out yet and the E40/Sabre comparison just needs to be done
Apr 19, 2016 at 3:32 PM Post #303 of 1,068
Thanks for the heads up! If the Phantom's sound anything like the E40's and fit better, I would be thrilled with the $89 price.
Edit: I should also clarify that the short nozzle would not be a problem if the tip itself was longer. As it is, the silicone tip ends only about 2-3 millimeters away from the end of the nozzle. The foam tips on my Westones extend 7-8 millimeters away from the nozzle.
Apr 19, 2016 at 7:58 PM Post #304 of 1,068
Which means it might get fixed with different tip?
Apr 20, 2016 at 2:17 PM Post #306 of 1,068
Another good IEM from audio-technica. I would buy E40 to upgrade from IM50. Maybe not the best for female vocal presentation (but I considered E40 still great for me). I like everything on it
Apr 20, 2016 at 7:39 PM Post #307 of 1,068
you've tried it? Lucky you...
Apr 20, 2016 at 8:19 PM Post #308 of 1,068
definitely there are still better iems at this price point
Apr 20, 2016 at 11:10 PM Post #309 of 1,068
Here, the price is Rp 1.250.000 (94.84 USD). IM70 1.175.000
There is are still better one? What is it?
Apr 21, 2016 at 12:00 AM Post #310 of 1,068
@Riposte Where did you demo it at ? Headfonia?
@Audio123 What good Dynamic Sealed with detachable, ear guide equipped IEM is better in this price point?
Apr 21, 2016 at 2:00 AM Post #311 of 1,068
i have the e40 its with me :p
Apr 21, 2016 at 2:00 AM Post #312 of 1,068
finalaudiodesign adagio 2/3
Finalaudiodesign heaven2
Havib3pro1
Ostrykc06
1more
Apr 21, 2016 at 3:55 AM Post #313 of 1,068
Havib3pro1
Ostrykc06
1more
I forget which one I've tried, adagio 2 or 3, and forget the impression
FAD Heaven II is good for vocals yes
I don't like B3 Pro1, KC06 too
I don't know 1more series, waiting someone buy it and bring it to local meetup
Apr 21, 2016 at 4:28 AM Post #314 of 1,068
Havib3pro1
Ostrykc06
1more
Does Havi have a detachable?
1 More: a bit hard to get a demo really... fakes everywhere...
Final I agree, but not for everyone, really.
As I asked, as a whole package, E40 is quite appealing
Apr 21, 2016 at 5:13 AM Post #315 of 1,068
Havib3pro1
Ostrykc06
1more
Finals are muddy, the rest should be good.
