Technex
- Nov 18, 2006
Hi guys,
I need your help to fix my Audio Technica ATH-A900's the pads have totally worn off... And I'm not a crazy fan about these standard pads too.
I hear that these are ideal replacements:
ATH-W5000 - Leather pads
ATH-A900Ti - Clarino man made leather pads
ATH-A1000 - Clarino man made leather pads
The ATH-W5000 were £40 ($65) which is a bit too steep!!
No one sells A900Ti spares in the UK it seems.
The standard ATH-A900 pads are just £5 ($8).
Are the A1000's a good middle range one to go for?
I am mainly looking for good bass and a long life.
Are there any other options?
Thanks,
Laurence
Thanks,
Laurence
