johnjen
The frequency response measurement itself is still a 'static' measurement, which is unlike music.Understand on static measurements...
But the frequency response curves of the system with/without fuses should tell you everything, no?
We are talking subtle nuances of phase and other circuitry response characteristics (slew rate, overall phase response, as well as possible impedance mismatches etc), due to the constantly changing voltage, current, waveform shape and frequency, all at the same time.
IOW we're talking about how well the circuitry can handle subtle nuances of the original music signal AND to see if we can make an 'improvement' to the devices SQ ability, all at the same time.
And when you think about it, ALL of the energy to deliver ALL of our music to us, MUST pass thru the fuse(s).
And so they can perceived as a 'choke point' (CP), a place where EVERYTHING downstream of each CP can be, will be, does get, affected, in some form or other.
And in some cases these CP's can actually make an audible impact on SQ that while seemingly subtle can add an inordinate amount of pleasure while listening to music.
Fuses are an easily overlooked aspect of any design, after all their primary and only real important job is keep your device from overcooking itself and causing a house fire.
Ya know, fire damage and insurance claims and and all that.
RIGHT?
Uhmmm, no, not in all cases.
Fuses are amongst the most simple, straight forward and refundable (should you decide they don't work for you) 'tweak', that more often than not, anyone can implement to see if they are of any benefit, or not.
JJ
