johnjen
Depending upon your budget of course, I'd start with the power amp then move to the dac and ddc last.
Why?
Because the power draw from the amp is the most dynamic while the digital devices use a more consistent amount of ac power.
These 'tweako' fuses tend to 'favor' the changing demands for power (the amp) over the more steady supply of current that the digital devices present to the fuse.
But if you want to shotgun them all at the same time, the break-in time, overall, will be less since they will all be settling in at the same time.
JJ
Why?
JJ
