Audio-gd USB-32 Firmware, Drivers, and Feedback Thread
Discussion in 'Computer Audio' started by petercraig, Nov 26, 2012.
Tags:
23 24 25 26 27 28 29 30 31 32
34 35 36 37 38 39 40 41 42 43
  1. conquerator2
    I got the DI-V2014 working today. For 2.5 mins! It was joy when it lasted -_-
    Now getting an 'enumerate filter failed' every time... Sigh [​IMG]
    When it works, it sounds great [​IMG]
  2. astalavista
    How to check version of firmware for Audio-GD NFB-1S(Version 2014 ) ?
  3. pikajude
    Just got my NFB-15 and hooked it up to my Macbook's USB 3.0 port. After about a minute or two, audio cuts out with a "kzzzkkk" sound and then I get a series of crackles until I go back into Audio MIDI Setup and change the output format. The time it takes the audio to cut out depends on what frequency I have my output at. It lasts the longest with 96kHz and about a second with 192. Anything above that is static and anything below 96 has a persistent cracking noise overlaid on the music like a jackhammer is running. What am I doing wrong?
  4. lucianpescaru
    Try a different USB cable and/or another USB 2.0 port.
  5. GrdironTrenches
    new owner of the NFB-3DAC coming from a pci soundcard (lol huge improvement). paired with he-560 and a project ember. im in love. foobars equalizer and plugins only seem to mud sound quality. arent there some Audio GD equipment with a software console for equalizer adjustments. would like to play around with bass boosting
  6. pikajude
    Same problem with a different cable. I only have one USB 2.0 port. Audio cuts out when using iTunes, Spotify, or watching Youtube videos in Safari. Chrome plays (most) Youtube videos just fine. Interestingly, girlfriend's laptop can handle it just fine, and it also shows up as "audio-gd USB audio", whereas on mine it's "Audio-gd". Her iTunes and youtube videos work as expected.
  7. pikajude
    Accidental triple post
  8. pikajude
  9. pikajude
    Well, if my triple post didn't make me look like enough of an idiot, here's the solution to round it off nicely. The OS X El Capitan audio driver looks to be a bit buggy. Restored my laptop from my Yosemite backup and everything is rosy.
  10. Matthew720
    Yo guys every time i try to set my NFB 15 default format from 2 channel, 32, 192000 Hz (Studio Quality) To 2 channel, 32 bit, 384000 Hz (Studio Quality) I only hear Static noise. Can anyone help with that?
  11. darren700
    Try a different USB port, or USB 3.0:
    The USB32 board has been pretty solid for me so far, the only issue I have had with it is it does not like the USB2.0 ports on my X58 Motherboard, I had the same issues only able to do 24/48 when plugged into my X58 USB2.0
    USB 3.0 on the same motherboard works perfect though for all frequencies, DSD included
  12. lucianpescaru
    This is an old post you quoted, I have sorted it in the meantime (can select up to 32/384), I changed the cable for a quality one and then for the original that comes from Audio Gd.
  13. bballas
    Amanero Combo 384 USB Interface (With official license)
    Supported Sample Rates
    44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz
    Output Format
    I2S 32bit or DSD64,DSD128 - On Windows DSD256,DSD512 too
    NO Drivers needed for Mac OSX 10.6+ and Linux with UAC2 compliant kernel.
    KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win8 32-64bit included at no fee.
     (176.4kHz, 192kHz, 352kHz,384kHz and DSD are only available in USB audio class 2.0 and 3.0 / High speed mode . USB audio class 1.0 / 1.1 support up to 96K /24bit )
    More inform : http://www.amanero.com/
    Price : USD90 (Exclude shipping fees)
    Users can setting the module power supply from USB or external power .
    Size : 70 X 45 MM (Exclude the USB port )
  14. gevorg
    ^Nice! I hope AGD would offer to replace their USB32 interface with Amanero USB as a custom option.
  15. bballas
    After usb 32 mod.(add 2 rail separate power for the tcxo,and firmware chip)the sound also amazing.
