Audio-gd USB-32 Firmware, Drivers, and Feedback Thread
post-11730188
Post #496 of 642
aive
After usb 32 mod.(add 2 rail separate power for the tcxo,and firmware chip)the sound also amazing.
Are you able to confirm results following your mods? My previous measurements of the USB32 indicated that it may be suffering from significant distortion issues (maybe it's only limited to my unit)...
post #2813
post-11730249
Post #497 of 642
bballas
Shenzhen
Shenzhen
I just use listening test.First step give separated 3.3v for tcxo,and listen.Wow!!much better.second step give 3.3v firmware chip,and listen,also better.third step, find some important line,give 3.3v but hear nothing.
post-11732604
Post #498 of 642
undersys
Amanero Combo 384 USB Interface (With official license)
Supported Sample Rates
44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz
Output Format
I2S 32bit or DSD64,DSD128 - On Windows DSD256,DSD512 too
NO Drivers needed for Mac OSX 10.6+ and Linux with UAC2 compliant kernel.
KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win8 32-64bit included at no fee.
 (176.4kHz, 192kHz, 352kHz,384kHz and DSD are only available in USB audio class 2.0 and 3.0 / High speed mode . USB audio class 1.0 / 1.1 support up to 96K /24bit )
More inform : http://www.amanero.com/
Price : USD90 (Exclude shipping fees)
Users can setting the module power supply from USB or external power .
Size : 70 X 45 MM (Exclude the USB port )
Yeah It looks like it may fit size wise..
Wonder if kingwa will offer a TXO upgrade too?
post-11733200
Post #499 of 642
Miracle1980
Do you guys expect "real" audio improvements with this new usb module compared to VIA one?
Or it is just a driver compatibility improvement?
post-11733330
Post #500 of 642
aive
I'd expect real improvements. I think the USB32 has distortion issues...
post-11733347
Post #501 of 642
Miracle1980
I owned 2 (still own one) dac from Audio-Gd with USB32 from VIA and never had a distortion issue. Only some compatibility issue with Linux, but it was firmware related...
If USB32 would have distortion issue it means that all the Audio-Gd dacs sold till now should be affected...
post-11733352
Post #502 of 642
aive
Have you measured it?
post-11733360
Post #503 of 642
aroldan
I have a USB32 module and I did this tests:
https://people.xiph.org/~xiphmont/demo/neil-young.html#toc_1ch
I found that this DAC implementation has IMD.
post-11733363
Post #504 of 642
Miracle1980
No. I didn't measure it. But i assume that it was measured from Audio-Gd and all the people that rewieved or tested these dacs...
post-11733444
Post #505 of 642
Miracle1980
I didn't make the test and, to be honest, i really don't know if this can be realted to the usb module, to your specific unit or to the dac itself (in general). Who knows if 90% of the dacs on the market would fail these tests...
Have you asked Kingwa about it? Or anybody asked him about the real differences between the 2 usb modules and if there is ''an upgrade'' plan for Audio-Gd dac owners?
post-11795248
Post #508 of 642
bballas
Shenzhen
Shenzhen
I know this problem.Trial older driver,or buy new firmware chip.
post-11803719
Post #510 of 642
tabm
I can't get my Audio-gd DAC to work under Windows 10 in apps like PotPlayer. Everything was perfect on Windows 8.1. It works in Foobar via Asio4all however.
