Audio-gd USB-32 Firmware, Drivers, and Feedback Thread
post-11218041
Post #436 of 642
barretp
Can someone help me out with my NFB-28? I'm on Windows 8.1 x64. I think I've installed the drivers correctly, however whenever I installed them, it said driver version 1.2 (Is that the latest version?). When I select playback device it says SPDIF Interface. I thought SPDIF was only the optical chord.
I can get audio through Foobar2000 and Windows system sounds, but that's all. Is there any way to hear audio from Spotify or Chrome, Firefox?
Edit: I think I've found my issue, I had the default sample rate set too high. I changed it from 2 channel, 32 bit, 384000Hz to 2 channel, 32 bit, 192000Hz.
post-11290315
Post #437 of 642
conquerator2
Czechia
Czechia
Website
www.youtube.com
Just a heads-up, the issues I've had with the DI's USB... Seemed to have been resolved by installing the latest drivers. I've been using the previous revision drivers and they seemed to work fine but those new ones seem to solve lots of issues people have had with their Audio-gd DACs [blue screens, etc.]
Well, I'll keep watching for a few days and if things stay fine, then I guess all's good.
post-11290388
Post #438 of 642
max785
I got the lastest driver and I get alot of bluescreens !!
post-11290391
Post #439 of 642
conquerator2
Czechia
Czechia
Website
www.youtube.com
Sorry to hear that... Maybe it won't solve every issue
post-11292994
Post #442 of 642
SpirosG
that' s a little bit peculiar ... I, -with win7-, dont' have bs any more, since I installed the latest driver ...
post-11293589
Post #444 of 642
conquerator2
Czechia
Czechia
Website
www.youtube.com
post-11293706
Post #445 of 642
max785
  No from the home website - http://www.audio-gd.com/En%20audio-gd.htm
There's a version 2 in the top center part.
wow it worked ! I can even see asio in the output pannel of foobar !!!! THANKS
Is it normal that wasapi ( event ) sound better then asio : via ks direct asio ??
post-11293720
Post #446 of 642
conquerator2
Czechia
Czechia
Website
www.youtube.com
Should be the other way around technically...
But it doesn't matter :]
Both are exclusive modes.
As long as it works now, don't worry about it :}
post-11295017
Post #447 of 642
SpirosG
what a relief ! I was becoming nervous that -even with the latest (version 2) - the blue-screens will apear again ...
post-11323152
Post #448 of 642
Gloomy Moonie
So to confirm, as of now, there aren't any issues with the drivers, correct?
About to pull the trigger on the NFB-15, so if there's anything I need to know - do tell.
post-11336414
Post #449 of 642
Honkytime
Buy it you wont be disappointed
Cheers
post-11350069
Post #450 of 642
Anda
Has anyone tried the USB-32 with the new Raspberry Pi 2? I'm using a SA-1.32 recognized as SVB-202D in Linux.
I have a Lenovo T500 and Raspberry Pi 2, both running up-to-date Arch Linux.
The SA-1.32 works fine on my Lenovo, but I'm having some issues with the Pi 2. Below are some results from a simple speaker-test.
It seems my problem has something to do with the buffer handling. The samples are played around 4 times faster on Pi2 (that's also what I hear).
I also did some tests with aplay which resulted in "underrun!!!" errors.
Raspberry Pi 2:
[anda@alarmpi ~]$ speaker-test -l 5 -t wav -c 2 -D hw:1,0 -b 1000000
speaker-test 1.0.28
Playback device is hw:1,0
Stream parameters are 48000Hz, S16_LE, 2 channels
WAV file(s)
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 48 to 262144
Period size range from 24 to 131072
Requested buffer time 1000000 us
Periods = 4
was set period_size = 12000
was set buffer_size = 48000
 0 - Front Left
 1 - Front Right
Time per period = 0.584356
 0 - Front Left
 1 - Front Right
Time per period = 0.750027
 0 - Front Left
 1 - Front Right
Time per period = 0.749841
 0 - Front Left
 1 - Front Right
Time per period = 0.750216
 0 - Front Left
 1 - Front Right
Time per period = 0.750286
Lenovo T500
[anda@copperhead ~ ]$ speaker-test -l 5 -t wav -c 2 -D hw:1,0 -b 1000000
speaker-test 1.0.28
WAV file(s)
Periods = 4
 0 - Front Left
 1 - Front Right
Time per period = 2,251276
 0 - Front Left
 1 - Front Right
Time per period = 2,999977
 0 - Front Left
 1 - Front Right
Time per period = 2,999963
 0 - Front Left
 1 - Front Right
Time per period = 3,000034
 0 - Front Left
 1 - Front Right
Time per period = 2,999969
Does anyone know if there are some issues with VIA VT1731 on RasPi or similar hardware. Any suggestions on how to resolve this?
EDIT: I have no issues with my Gustard U10 (XMOS)
