Audio-gd USB-32 Firmware, Drivers, and Feedback Thread
post-11136946
Post #421 of 642
saintkrusher
Hi friends
I need firmware update tool with firmware 2014V3. On the site Audio-gd isn't available. Please help me!!!
post-11137305
Post #422 of 642
conquerator2
Czechia
Czechia
Website
www.youtube.com
  Hi friends
Write directly to Audio-gd. They will send it to you - audio-gd@126.com
post-11138560
Post #423 of 642
max785
Did someone had the same issue ?
I have an nfb-3 dac on usb and i'm using win 7 x64 with foobar. I'm trying to use the output device ASIO like the picture :  http://www.audio-gd.com/Pro/dac/USB32/Step8.jpg. I followed all the step, but i'm not able to see it in the list. I only have Null , ds , ks and wasapi available ...
post-11138715
Post #424 of 642
Heprer
Reinstall it.
Did you deleted the installer folder "Audio-gdUSB32driverversion1"
I am a noobie but when i've installed mine, in foobar there was ASIO: via ks asio , but then i've deleted the installer folder to clean my desktop, after that i couldn't see the via asio in foobar. The problem was that foobar was using the
Audio-gdUSB32driverversion1\viaudusb\VIA ASIO "viaasio.dll" from installer folder and not from where it was installed
C:\Program Files (x86)\VIA\Setup\viaudusb\VIA ASIO
I've uninstalled it then moved the install folder "Audio-gdUSB32driverversion1" on c program files ( so i could keep my desktop clean) and then installed it and it worked.
I've tested again and, yes if i were to move "Audio-gdUSB32driverversion1" then it would not work anymore.
Hope it helps
post-11138827
Post #425 of 642
max785
Did that but it's not working either ...
post-11139694
Post #427 of 642
Jakkal
Make sure that in Foobar the option "Use 64-bit ASIO drivers" is unchecked!
post-11140448
Post #428 of 642
d4b0
Managed to get Jplay Extream engine to work with KS Audio-GD to play both PCM and DSD materials. Buffer settings are as followed:
Buffer - 128
96Buffer - 256
192Buffer - 512
With these settings, KS Audio-GD works both on Jplaymini and also under Jriver with Jplay ASIO as the device. Set the buffer with Jplaysettings.
does it mean you can play DSD256 and DSD512 files?
post-11140449
Post #429 of 642
max785
post-11140822
Post #430 of 642
Heprer
After installation you have a via asio shortcut on desktop, does it work or it gives you "enumerate filter failed"? (you need to have the unit connected to pc)
If it works, then i don't know reinstall foobar, maybe it is something wrong with it.
post-11141225
Post #431 of 642
max785
 Give me that error only when the dac is not on.
post-11148260
Post #432 of 642
DMax99
Does the Di v3 have compatibility issue with some dacs?
When mine is connected to the wyred4sound dac 2 via Coaxial, the music skips in 192k mode but ok with 96k mode.
Any idea what the problem might be? It works fine with other dacs in 192k mode.
post-11154886
Post #433 of 642
mtan002
NFB1 plays only DSD64 and DSD128 well. Had some issues with DSD256 files at the moment. Continuous pops.
post-11184386
Post #434 of 642
barretp
So I tried upgraded my firmware on my NFB-28 with the file Kingwa gave me and it failed and now it's bricked. Do I have any options?
post-11184592
Post #435 of 642
undersys
Order a new flash chip from him.
Its on a pin header and is easy to swap out.
I do this all the time, since i have no windows machines to update the f/w...
