Running SE or balance?
And would you tell some more details about sound in this nfb28+he500s combo. Cuz i'm allready have 500s cans and in one step from buying 28
Started running stock SE for the first 3 days before my 66$ lunashop balanced cable came. Balance gave that last little bit of chrispness i was hopping for. This was my first time hearing a balance setup, about the improvement i expected but i was sort of wishing to plug in the new cable, go form 2 to 4 chanels in use, and get some plato leaving the cave type of change.
I ive been trying to start a real review but i just gathered up the initiative to stop lurking. I probably wont get around to it until ive sampled a system or 2 that can compare.
Ive had a portable JDS Labs C5D => Dunu dn-2000 portable rig (2 by 1 hybrid that sounds 'like headphones') for about 18 months and i can say the He-500/ NFB-28 is better in almost every possible way. Very noticably better Tone, smoothness, and dynamics; everything sounds very alive and musical. Imaging and frequency range are just as good if not better on the desktop pair. One thing that might be lacking is transparancy, with the dn-2000 the mids ride over the base hits with this almost unnatural cleanness.
All in all i couldnt like my hifi buys more. I believe every time you double how much you spend you can get maybe a 5% 'improvement' in SQ if you spend your money well. By that standard I think the NFB-28 is a total steal and truely my endgame system. I work in a factory setting and i think to hear anything better id need to invest in replacement bionic ears first.
If i ever have really have the urge to get something new i might look at something by audeze as im a sucker for a warm thick mid range. but that wont be for a year or 3 and im pretty sure ill be happy using the 28 for any headphone I might hope to get.
EDIT: Only other amp i tried with the he-500 was an Onkyo hometheater receiver getting music from my portable amp/dac via RCA. This setup had plenty of power but no finesse, I heard my 500's for the first time the day the NFB-28 arrived
