I get all that, but my question was in reference to upgrading your OS from a good one to a bad one just for 32 bit audio. I know for some of us, upgrading the OS is something we do often and not a big deal. Yet it can lead to many problems (as you have shown). It's a big step to take just to prove a point about a feature you will literally NOT USE at least for the lifetime of your current OS.
To go back to your Ferrari metaphor, it's like bulldozing your house and building a track instead just to test the top speed once. At least IMO.
Anyways, different stroke for different folks. It's not my intention to insult or get you worked up. I apologize. I hope you enjoy your NFB-28 and HE-560 as much as I do!
I am upgrading windows for similar principles to what I just mentioned. Audio is just one small reason. Otherwise.... Windows 8.1 implements UEFI or Unified Extensible Firmware Interface with secureboot. Well, it does it better than windows 7 anyways. The boot times are significantly less with windows 8. Also the direct X supports newer versions with more features than the windows 7 direct X. 11.2 vs 11... A clear winner.
http://www.hardocp.com/article/2013/11/24/battlefield_4_windows_7_vs_81_performance_review/5#.VRWD0vnF98E
or copied and pasted from this article.
Performance Advantage
Is there a performance advantage in Windows 8.1 versus Windows 7 for BF4? The answer is, "Yes." We consistently found that under Windows 8.1 BF4performed faster than Windows 7 on both AMD and NVIDIA hardware. Both GPUs, from both vendors, had a consistent performance advantage in every test we performed. More importantly, in the real-world multiplayer gaming session that matters, there was a performance advantage.
Now, this performance advantage is small on the R9 290X at around 3%. It is larger on the GTX 780 at around 6%. We found this more interesting. It seems the GeForce GTX 780 was more advantageous in performance under Windows 8.1 than the R9 290X was. We did not expect that. With all the work AMD has put intoBF4 and DX11.1, we figured the R9 290X would show the highest performance advantages. However, the reverse is true. It is the NVIDIA GeForce GTX 780 that is benefiting the most from Windows 8.1.
Gameplay Image Quality Advantage
Was there an advantage to the image quality settings under Windows 8.1? The answer is "No." The performance advantages were generally small at 3-6%. This isn’t enough of a performance boost to allow us to raise the resolution, or raise the AA settings, or raise an image quality setting. We were not able to play at different game settings under Windows 8.1 versus Windows 7. This means the game will look the same under both operating systems.
Gameplay Experience Advantages
Are there gameplay experience advantages under Windows 8.1 versus Windows 7 in BF4? The answer is a, "Big YES."
Under Windows 7, we experienced choppiness as we played. This was felt both in the "Test Range" map, and in multiplayer gaming sessions. The choppiness was more pronounced on the GeForce GTX 780. We could get on a straight path, in the "Test Range" and move down a straight road. As we did this, there would be a pause, or chop, in the frames randomly. It was like the game was hitching for no reason. This happened more on the GTX 780. This is under Windows 7.
When we tried this on Windows 8.1 the pausing, or hitching, or chop (however you want to describe it) was completely gone. Moving was smoother with no hitching in the game on the GTX 780. This affected both the test range and the multiplayer gaming session.
Therefore, the gameplay experience advantage under Windows 8.1 is a smoother gameplay experience in BF4 on both video cards."
I'm a gamer too, and 6% performance, and no more stutters or hangups in my games is significant to me. Windows 8.1 is a better operating system, albeit a large learning curve to get used to it. I'm ok with that. UEFI is the future and this operating system integrated peripherals and hardware better than ever. So 32bit sound is like one sprinkle on top. I had this planned either way. I am having issues as I'm trying to fully understand the UEFI setup of windows in combination with all my hardware. My microsoft buddy picked me up a copy of 8.1 pro for 40 bucks so why not?
basically, I purchased a great computer and it's video card is a Kingpin 780TI. I would like it to perform at it's best. That would be in windows 8.1 where it can utilize it's DirectX 11.2 that it supports. Why not?
I've found that randomly my DVDROM took a crap on me and is why I couldn't get things to load properly. A new one will arrive today. So hopefully i'll have windows 8.1 all loaded this weekend. I'll set it up to have the classic start menu and all is good. I would prefer to learn about new technology as it comes out.
