Audio-GD NFB-11.32 & NFB-11 (2014) (Delivery & Impression Thread)!!!
Sep 19, 2013 at 1:35 PM Post #992 of 3,093
The specs on the nfb 11.32 single ended output look very similar to those of the nfb 10es2 single ended output. Do they use the same amp stage?
Sep 19, 2013 at 6:00 PM Post #994 of 3,093
Silly question but whats the difference between the 11.32 and the 15.32? there isn't many reviews and impressions of the 15.32
Sep 19, 2013 at 6:11 PM Post #995 of 3,093
The 15.32 uses two wolfen dacs one for each channel while having the option of Digital Filters thru the switches on the front of the unit, While the 11.32 uses one Ess Sabre Dac and do not have the use of the Digital filters.  Other then that they are similar but suppose to sound different then each other but I do not have the 11.32 as I went for the 15.32 instead.
Sep 19, 2013 at 7:14 PM Post #996 of 3,093
I find the 15.32 to be quite warm and musical as an amp. As a dac it retrieves quite a lot of detail. Is the Sabre better than the Wolfson?
Sep 19, 2013 at 8:05 PM Post #997 of 3,093
From my understanding, the ESS9018, for the most part is considered to be a higher end chip than the wolfsons.  Many top end DACs such as the Burson Conductor uses the ESS9018.  However, it ultimately goes down to your taste in signature.  The Wolfsons are indeed warmer sounding while the Sabre chip is a lot more neutral and detailed.  Depending on which headphones you plan to use, you may prefer one dac over the other.  The Sabre chips will work better with warmer headphones such as the HD650 and HD600 and help remove the so called "veil", while the Wolfson chips will add more warmth to leaner sounding headphones such as the Q701 and maybe the DT880s.
Sep 20, 2013 at 3:44 AM Post #999 of 3,093
would hooking it up to a neutral sounding amp also have the same result?
Sep 26, 2013 at 4:47 PM Post #1,002 of 3,093
  Anyone know if the newer units are still using the new ES9018K2M chips, or just the standard ES9018 chips?
From what I have read it seems the ES9018K2M is a lower grade of chip than the ES9018.
I have seen it advertised for $20 each!
Sep 26, 2013 at 5:08 PM Post #1,003 of 3,093
When did they start using the newer chips?
Sep 26, 2013 at 5:51 PM Post #1,004 of 3,093
Sep 26, 2013 at 5:56 PM Post #1,005 of 3,093
Who said they were?
Someone asked this question "Anyone know if the newer units are still using the new ES9018K2M chips, or just the standard ES9018 chips?"
