bruce108
- Sep 19, 2006
Right, voltage v current.
[size=medium]Hi Kingwa,[/size]
[size=medium]reading about usb audio standard I think I know now where lies a problem with firmware #4.[/size]
[size=medium]Here for example is not too technical explanation about usb audio:[/size]
[size=medium] http://www.edn.com/design/consumer/4376143/Fundamentals-of-USB-Audio?page=2[/size]
[size=medium]and you can read that feedback format should be 16.16.[/size]
[size=medium]This lead me to usb 2.0 specification and in point 5.12.4.2 you have:[/size]
[size=medium]“For high-speed endpoints, the value shall be encoded in an unsigned 12.13 format which fits into four bytes.[/size]
[size=medium] The value shall be aligned into these four bytes so that the binary point is located between the second and[/size]
[size=medium] the third byte so that it has a 16.16 format.”[/size]
[size=medium]Firmware #4 uses 14.18 feedback format. This must lead to incorrect calculation of momentary frequency,[/size]
[size=medium]when to send next portion of data. This is why Linux try to send 44.1kHz audio stream with frequency of 48kHz.[/size]
[size=medium]And this must cause buffer overflow in DAC.[/size]
[size=medium]Can someone check firmware #4 under Mac OS? Mac should expect standard 16.16 format too. [/size]
[size=medium]Kingwa could you prepare firmware #5 with standard implementation of usb audio with 16.16 feedback format?[/size]
[size=medium]Then we will be able to test it.[/size]
I was wondering if anyone has had any success using an android device to feed USB audio to this thing. I was thinking about switching to an android device as my primary source. If anyone has a Galaxy SIII or a note II, as well as a USB OTG cable they can test this out.
Hi Jlav,
I've got a Samsung Note 2 and the Compass 2 from Audio-GD. Need to grab a OTG cable somewhere and will test it one of these days. Will report back results when available.
Steve
Hi Jlav,
Steve
Thanks for the info. Did you use an OTG cable?
