RojasTKD
- Jan 14, 2009
Could I get a recommendation between r2r11 and nfb11? I use Hifiman HE-400i, this program https://fongaudio.com/out-of-your-head-software/ for movies, and fast complex music. I know nfb11 is a good choice for my needs, however, the he400i is very analytical, would the r2r11 add some life/realism without sacrificing detail and speed? Also, between the "out of your head" program and equalizing I find I need alot of power, will I hear the noise floor on r2r11 if the volume is high? Thanks!
About to place an order for the R2R11. Is there consensus that it pairs slightly better with the HD 6xx (650) than the NFB version? Most people are choosing the R2R from what I can tell, but I haven't seen much informed comparison/opinion on the pairing aspect. That said, any opinions informed or not so well informed are welcome. I'd especially like to know if soundstage is any different between R2R and NFB. Thx
I can't speak for the latest version of the NFB-11.28, but I have an older NFB-11 (2014/2015) and a new R2R 11. Honestly so far Ive been hard pressed to tell much of a difference. If I listen really carefully (and repeatedly) with my HE-500s I noticed difference in things like cymbal hits and claps. It seemed sharper and more realistic, aside from that it was had to distinguish one from the other.
There may be a greater difference with the new NFB-11.28 and over time I may be able to develop better hearing for some differences. But honestly I wouldn't worry too much. Either one will deliver great sound and likely make you happy.
The one thing that bothers me is that Equalizer APO (system wide EQ app) dosen't seem to work. I'll have to look into it and see if there is a fix. It worked fine with my older NFB-11. I'm not sure if this will affect you "Fongaudio" application.
