gimmeheadroom
The bad news is that this is a general flaw in all the R2R-11 units that I’m personally aware of. It’s limited to DSD playback like you say, and mainly noticeable in quieter passages of classical and jazz music. In fact, most of my classical DSDs are now unplayable on the R2R-11, and so I’ve set Audirvana to convert DSD to PCM on the fly. Still sounds fantastic, but of course if you want native DSD, too bad.
Also as far as I know there’s no fix for it. They’ve supposedly fixed the pops, but I haven’t yet heard any feedback on whether or not the firmware update addresses the DSD issue. In my many discussions with Kingwa - via my local agent - he claims the noise is there because as a NOS dac, it doesn’t and won’t filter any low level noise artefacts - even though he couldn’t explain why these were limited to DSD playback.
Since ladder dacs have no way to actually play DSD files natively, I can only assume it’s a fault with the DSD playback chip or module or whatever else they’re using to actually “play” native DSD, if in fact it’s being played back natively at all.
Bottom line, if you have lots of DSDs - especially classical and jazz - and insist on playing them without PCM conversion, then however much it pains me to say it, the R2R-11 is (currently) not the solution. I really hope it gets fixed, otherwise it won’t be my long term solution either, however brilliant the sound (and it is brilliant with all my headphones).
PS. An even bigger question for me is if the same noise is present in the R2R-1 and R2R-2 dacs, because one of those were going to be my upgrade path. However if they also have issues with DSD playback, I’ll be forced to look elsewhere, and probably abandon Audio-GD altogether. I really hope it doesn’t come to that.
Well crap. I ordered the R2R-11 after reading about 60 pages of this thread and then I started seeing your comments about DSD not playing. I'm still reading and hoping this is resolved.
