ClintonL
- Mar 15, 2012
does it matter what volume i have it at the nfb and what volume i keep in windows? like should i set my windows level high and amp level low or the other way around?
Can anyone tell me what differences installing the 32 bit module makes? Does it affect the sound signature? Is there a significant increase in sound quality?
Hello all! I'm interested in the NFB-10 as a pre amp for my living room. Can anyone clarify what happens to the sound when you press a volume button? Is there a momentary drop-out , a click, or other nasty? Also what does the display show? Anything apart from IHH200 whatever that means!?
Thanks.
The volume either increases or decreases. There's no drop-out.
Hey guys,
What do you think about Akg Q701 (balanced) that will be paired with NFB-10.32 ? Do you have alternative solutions for that? Source will be PC.
I've got a NFB-10SE running with hd650/he400s and looking to upgrade. Any ideas? Thinking of using the nfb as a preamp and buying another amp? Or how much around would i need to spend on a new dac/amp to get a improvement over it.
Cheers
