zenki14
- Sep 28, 2010
It would be hard to say which sounds better as the components used are so similar (like the R core transformer and DAC chips), power rating is the same, but the circuit design is different. The 10 series is inteded for balanced while the 3 series goes for single ended.
If you don't need XLR balanced outputs, and if you're not going to need the headphone amp section (4-pin XLR balanced and single end), then probably the NFB-3.33 is the choice, as it has the current USB32.
The 10SE is a discontinued model which has the old TE7022 for it's USB receiver. I think it can be replaced with the current USB32 module but it means extra money and hassles. I used to have the NFB-10.2 (a minor update after the 10SE which had the TE8802 instead. After this the current 10.32 with USB32 came out) so I know the DAC out and headphone amp section is great, but if you don't need the XLR balanced sections, the NFB-3.33 would be enough, imo.
Hi guys,
Any comparison between the NFB 10SE and NFB 3.33? Which will give me better sound quality? 10SE or 3.33?
Was initially planning to get a NFB 3.33 new, but came across the NFB 10SE second hand in the same price region.
So i thought if the 10SE is a better choice, i might go for it instead.
While reading, i read something like the USB module needs to be installed? it doesnt come pre-installed?
I be connecting the dac from my computer, so the usb connectability is quite important..
Comp > dac > active speakers (Adam A3X)
