FredA
- Dec 15, 2013
If i remember correctly, a jumper is needed on bypass. Otherwise, you bypass the dsp. It's reversed logic. Bypassing the dsp would cause a roll-off.That was an interesting issue with conversion of the old M7 to SIngularity DSP. For whatever reason the 1st Singularity board sent to me would not boot up consistently. I sent this board back to Kingwa and he said he could no find an issue. I had him send me a 2nd board that did much better. I did not completely resolve the issue as the old M7 was packed up and moved about the same time. The 2nd replacement board was better but could get it to do the same on repeated restarts of the warm DAC. Cold DAC starts are OK. The AGD procedure now is to wait 30 sec. before reapplying power.
The issue was discovered while constantly rebooting a warm DAC testing various DSP modes. But if the DAC sounds OK from the beginning then it will sound good until possible another power restart. Others users did not have this issue and my other two SIngularity DSP equipped DACs never have issue unless I don't wait enough time before reapplying power.
