Audio-Gd Master 7 - Discrete Fully Balanced DAC (PCM1704)
Discussion in 'High-end Audio Forum' started by darknightdk, Sep 3, 2012.
257 258 259 260 261 262 263 264 265 266
268 269 270 271 272 273 274 275 276
  1. alphanumerix1
    So the digital upgrade board is no longer available?
  2. alphanumerix1
    Are the op amps plug and play or did your friend have to solder them in?
  3. Whitigir
    They are plug and play, but my friend is comparing r2r7 and his now. The Burson is running underpowered due to the PS on the design, and so it can not extract the details as good on upper spectrum, so that as one of the reason why my r2r7 was obviously better
    alphanumerix1 likes this.
  4. seaice
    Does anyone know how to convert higher than 192kHz spdif signals to I2S? I will be buying Chord M Scaler soon and I would like to provide the best digital input to my to my A-Gd HE-7 Singularity. It means e.g.: Chord M Scaler with 500k TAPS settings will produce 352.8kHz output SPDIF signal. The only inputs of HE-7 Singularity that accept 352.8kHz are USB and I2S....
  5. Mahdi8
    Dupe
  6. Mahdi8
    You need something with akm4137 chip. Like this https://m.ebay.com.au/itm/LKS-AKM41...906734?hash=item1ec18793ae:g:3KIAAOSwdGFYonEm
    seaice likes this.
  7. seaice
  8. Whitigir
    No, I have LKS-004 and it I2S configuration is different than AudioGD.
    You can try a Singxer SU-1 ?
    Anyways, what I learned is that true Direct I2S is limited at 192Khz. There is only one type of chip that allow Direct I2S, and that is C-Media. Anything higher than 192Khz is not Direct I2S. It will have to be Digital-Digital-Conversions (DDC), for example the one linked above (LKS), and or Singxer SU-1
    seaice likes this.
  9. seaice
    Thanks! I would like to but the Singxer SU-1 is limited to 192kHz via SPDIF, see the Singxer web: [the I2S out and WCLK out support all sampling rate, S/PDIF and AES/EBU highest support 192 KHZ]
    I need an SPDIF (RCA or BNC) input capable of 352.8kHz.
  10. Whitigir
    I see, I thought as an DDC it should be higher. How about Matrix SPDIF2
    IIS:
    PCM 16-32Bit /44.1kHz、48kHz、88.2kHz、96kHz、176.4kHz、192kHz、352.8kHz、384kHz、705.6kHz、768kHz
    DSD64/128/256/(DoP) DSD64/128/256/512(Native)
    It should be better than Singxer SU1. It uses accusillicon and those are good stuff, the only better clocks would be an expensive SC-cut OCXO
    You may have to contact Matrix to make sure about the configuration that is compatible to LKS004! I have not looked into this, but whatever it is, as long as you can make your own custom cables, you can use whatever. I use Pinkfaun I2S configured for AudioGD but I made Cables for LKS004
  11. seaice
    This seems great but does it have a 352.8kHz SPDIF input (RCA or BNC) that can be converted to 352.8kHz I2S HDMI out?
    I would like to try this chain: PC USB > Chord Hugo M Scaler (500k TAPS) > 352.8kHz out > ??? > 352.8kHz input of HE-7 Singularity
  12. Whitigir
    Nope, only usb-input
  13. seaice
    Thanks! I will try direct 176.4kHz out of M Scaler via SPDIF to HE-7 Singularity first. If I undrestand it correctly it is 250k TAPS - more than my Dave has :)
  14. Whitigir
    Yeah, it is kinda funny that while Chord is increasing Taps length, IFI is decreasing it, and so does many others. But we all know Chord has their own things, and so it is best to stick with them and their eco system
  15. FredA
    Audirvana allows doing more TAPS than this if that correspomds to the sample window length used to compute then upsampled output.
    But i assume the output will be well clocked and that they use priopriatary algorithms so it could well worth the admission ticket, if well priced. However, they don’t provide jitter figures as far as i can tell.
    One thing with the r7, when used in 8x os mode, i prefer it to audirvana doing the same upsampling. So it does an excellent job imo.
