I know this is not gerenal if the users first time use the relays based volume control system.
Most products's volume port have applied the potentiometer have not any noise while change the volume, but the poteniometer is the worst volume control, usually have long wires connect to signal and imbalance exist .
The better is the step switch volume port , most have 24 to 48 steps, it is have not imbalance , but too less steps, and the signal connect to the volume have long wires cause the sound degrade.
And the steps volume port usually have same or even large level click noise in the signal than the relays based volume .
The another better volume port is the hifi Logic chips based volume port,, it can install close the circuit and no imbalance, but the impedance of the Logic chips is large, cause the signal have through the impedance and less applied now. Usually this mode still have the click while change the volume .
The relays have very low impedance in the relays and close the circuit , no imbalance, more steps , best in my mind .
So in our products, the low range have the ALPS volume port, no click .
High and mid range all with relays. More expensive, more complex design on the software , but just for better responsed on the sound quality.
Kingwa
