abhinit90
- Feb 12, 2011
If heat's a problem, then I wonder if it'll even be able to work at about 35-40 C. Which is the norm where I live.
Here's an idea of the space between my top bench and the M11.
The gap between the M11 and the top bench is approximately 6cm or 2.36inches.'
Yeah, it most definitely doesn't answer the recent questions in this thread.
BTW, in NOS mode, does the soundstage become more compact?
Since I am very satisfied with M11 NOS mode + HD800, I wonder if I should reconsider upgrading from stock to Norne Draug 2 cable. People say Draug 2 adds bass and body + removes etch, and i don't know if upgrading cables will make my HD800 sound overly bassy and rounds treble too much...
Just my instincts talking here but I wouldn't do it to mine. My machine becomes only warm to the touch and it's been up three days now. The cover seems heat sink enough. The was another poster who had pasted some topping on the chips that was supposed to make things 'better'. I believe heat issues soon arrived. Once you put it on, at some time you are going to take it off 'just to see' and then it's sticky residue on Chip blah blah and blah. I doubt the solution costs $1.99. Actually even a tiny fan blowing on a hot cover cools it down really well. I've testedI wonder if there would be any merit in installing one of these heatsinks onto the DSP?
http://www.moddiy.com/products/3M%252d8810-Black-Chipset-Heatsink-%2828mm-x-28mm-x-9mm%29.html
That was me. and it was with 3M EMI absorbtion material. BUT, the problem was NOT heat. After talking with kingwa, he states the DSP does not get hot, does not matter if it has EMI film on it. The "stuttering" i experienced was because I had the M11 on for many days, weeks or even a month straight without resetting the M11 as he recommended. He states 24x5, not 24x7... but that sounded confusing I thought. He just said it's like windows, needs to reboot once in a while. So a quick power off and reset is needed to reset the DSP once in a while. Otherwise stutters can happen. I have NOT removed any EMI film and never experienced a stutter since knowing this info from Kingwa.
I wouldn't bother with a heatsink myself, but the EMI is not a bad idea and definitely didn't make things worse. I have some photos showing all the areas I used it on. I can say my setup sounds nothing short of incredible imho.
and that EMI film is not cheap, one 8.5x11 sheet is around 60-80bucks from what I rememember. I don't remember if I posted the photos in the Dac19, master11 or nfb28 thread. I've added EMI film to my wife's NFB28 as well. no issues with heat, only need a dsp reset. My M11 was super warm that day, but still not enough to be a problem.
and a small low DB fan on top could make a difference to cool it down if you wanted...
sticky residue is easy to clean off BTW. Isopropyl Alcohol.
Have you try different USB port? Now a day, a motherboard contains many USB ports driving by different USB chips. For my computer, there would be this one port that would not work at all, so I just move my mouse and keyboards to that and use the other set for DAC output.
