johnzz4
So, I have the M11 with the HDMI i2s input option. I recently purchased a Singxer SU-1 USB Bridge, and the sound is amazing. Still burning in, but already a nice improvement over the Amanero (though the Amanero isn't a slouch). Anyway, from all my research about the PLL jumper, it sounds like with the PLL enabled (jumper off), the clocks inside the M11 are utilized to reclock the incoming signal. With PLL disabled (jumper on), it should be using the clock signal from the USB bridge as the master. Looking up the jitter values for the clock in the SU-1 look clearly superior to the values listed on the M11 web page.
Info on the SU-1:
SU-1 is the independent development low jitter clock digital system interface(CRYSTEK CCHD-575 SERIES).
Details at http://www.crystek.com/crystal/spec-sheets/clock/CCHD-575.pdf
Info on the M11: Master-Clock:
Clock Autodivide Circuit Supports four Master-Clock Frequencies : 256Fs、384Fs、512Fs、768Fs
Built-in two groups high performance PLL , supports low jitter Master-Clock output.
Details at http://audio-gd.com/Master/Master-11/M11EN.htm
After all that, the PLL enabled (jumper off) sounds MUCH smoother and more open which is exactly what I wouldn't expect. PLL disabled (jumper on) is edgy and quickly fatiguing.
Does anyone with more knowledge about PLLs and clocking have any thoughts?
Info on the SU-1:
