hidehide
- Apr 27, 2016
Based on my experience, which is M11 as multibit and Vi DAC as the delta sigma sabre based, I would say multibit is hood for vocal centric tracks and the rest I preferred the slightly more transparent, and clearer more impactful bass of the Vi DAC. I listen to 90% vocals, so M11 is still my most used DAC. M11 amp is #1 imho, having compared between the built in amp in the Vi and ragnarock.
That sounds good. Seems getting either the M11 or NFB-7 will be a nice dac+amp. Now it should be down to whether to get the PCM1704UK or ES9018 DAC chip..
But I do notice the Schiit combo looks like an art, while the look of the M11 is meh....
As it always comes down to ones taste I can weigh in on how I hear things.
First off the M7 and 11 and the older ref 7.1 are all warm of neutral period and play PCM and down sampled dsd very well. It has a sound for me hat is pleasing in all formats. Now a word about sabre Dacs. For me they are not pleasing weather warm or neutral. I have a owned a few of them as well. Now some do sound better than others.
My point in this is what your taste is not mine or others who post hear. All of the audio gd line is musical but hi wit seems to you is your choice.
Lastly if I were you buy a used M7 or what ever and keep the amp a separate device. The why is simple a combo is locked in while two devices gives you more choices to find your taste. Hope this helps some and in no way am I being sarcastic for others views.
I got your point. And the M7 should be superior than the M11.. But that will be over my budget.. and if I have the money to buy M7, I probably will go for Schiit Ygg..
So I will probably stick with the combo unit.. And this will be my first and end game equipment..
