Audio-gd Digital Interface
Apr 20, 2014 at 8:25 AM Post #3,992 of 4,156
  Kingwa forgot to put the news about the DI-V3 2014 firmware, but we can download it from here:
http://www.audio-gd.com/Pro/dac/USB32/USB32EN_2.htm
:wink:
In the manual says that we must use firmware 2014 with driver 2014.
I already sent and email to Kingwa asking about the driver 2014 for DI-V3...
Apr 20, 2014 at 9:36 AM Post #3,993 of 4,156
DI-V3 can use the Driver 2014 (24bit only)...
Firmware 2014
http://www.audio-gd.com/USB32firmware.rar
Driver 2014
http://www.audio-gd.com/USB32%20driver%202014.rar
May 21, 2014 at 3:24 AM Post #3,994 of 4,156
I have the Audio GD DI v1 and PSU v1.
Yesterday i bought a DI v3 and with a bit of luck I receive it today.
I have a question about the PSU however.
On the website of Audio GD I read the following. For old PSU v1 : Addition one 10 ohm / 0.5W resistor
I am not a electric engineer, but I hope I understand it. I think I have to replace the current one with another one. Right?
I think it is the part I marked with arrows.
Can someone explain to me why I have to replace it? The output stays the same, so I do not understand.
Hope that someone with more knowledge can help me out.
May 21, 2014 at 6:23 AM Post #3,995 of 4,156
By adding resistors in parallel to existing two blue resistors (shown as "additional green resistor" on the picture) you raise output current. Voltage stays the same.
"Mo' powa'."
More heat too.
NOTE:
  • CONTACT AUDIO-GD FOR EXACT RESISTOR VALUES TO BE SOLDERED IN MARKED POSITION.
  • TWO EXISTING BLUE RESISTORS SHOULD NOT BE REMOVED.
  • BIG 0.5W BLACK RESISTOR (marked with red X on the picture) SHOULD NOT BE REMOVED OR CHANGED IN ANY WAY.
May 21, 2014 at 8:43 AM Post #3,996 of 4,156
By adding resistors in parallel there (NOT REPLACING) you raise output current. Voltage stays the same.
"Mo' powa'."
More heat too.
I can follow you thanks
Still one question. Did I pick the right part (see picture in my previous post) or is it the blue one left of it. I am in doubt....
May 22, 2014 at 5:49 AM Post #3,997 of 4,156
Yes, you were right...
I checked back my notes and correspondence with KingWa and fixed accordingly my previous post: Resistor(s) should be added to two existing blue ones... big black one should not be touched.
Jul 17, 2014 at 12:05 PM Post #4,002 of 4,156
Audio-GD's new DI-2014 details are up, they'll be shipping out early August! It looks like the biggest changes here are:
1. DSD output via I2s (but not SPDIF)
2. The PSU has been placed on-board and only comes with this option
3. The PSU around various components have been built up even further (primarily around the USB chip)
4. Shorter signal transfer lengths
5. No power transfer via USB cable, signal transfer only
http://audio-gd.com/Pro/dac/DI2014/DI2014EN.htm
I like what I see!
Jul 25, 2014 at 10:02 AM Post #4,003 of 4,156
Hi guys,
I sent the question to Kingwa, but he's not available right now......So in case anyone would know....
I have the REF5 I bought in 2012 I believe... I am using the DI 1 bought at the same time....
Would the DI 2014 improve the sound of the REF5 (the maximum the REF5 is 24/96).
Just wondering
Thanks
Denys
Jul 25, 2014 at 11:38 AM Post #4,004 of 4,156
Kingwa would know, since no one has tested it yet.
In blind tests between FLAC 16/44.1 and 24/96 you will hardly find any differences, so higher than 24/96 is overkill and will not be noticed at all. The differences have to do with jitter more than anything else.
Jul 25, 2014 at 12:14 PM Post #4,005 of 4,156
So I believe my question should be.... Will I hear an significant improvement between the DI 1 and the DI 2014 to justify the purchase of the DI 2014.
I know the REF will not read DSD file.....but I am not too concerned about that... I'll wait for Kingwa's answer then...
Denys
