drez
- Sep 7, 2009
Well, I changed my power cord from computer to the Audio-GD DI and it improved very much. Now I'm buying another power cord for my PC to see what happens, I really don't know if this time there will be an improvement in sound because the clock is off the computer, but for the piece of mind...
I don't feel anymore like maybe I should have invested this money in another piece of gear. By the way, looks like the upsampling works better than no upsampling. People say it sounds a little harsh without 'burn in' but this is exactly the opposite I found compared to the stock setting. Lets see what happens in some days, than I'll try to compare both again.
One of the big differences I found with my DI right now was that the soundstage improved very much, stereo separation and there is more height, vocals are higher in space than other instruments, decay is longer too.
And I bought the USB Isolator and the Furutech GT2 cable, I hope both improves the sound too.
With 44.1 khz material I find that the upsampling tends to smooth over a lot of the low level details and I would only recommend it if you have problems with the DI when running without upsampling. Other reviews tend to concur that the upsampling isn't optimal for 44.1 material - but you may like it depending on personal preference.
Don't understand what you mean by "power cord from computer to the Audio-GD DI" - are you running some sort of power arrangement from your computer PSU? Or are you running the AGD power supply? Which power cable are you using?
