sajunky
Good observation. I think main purpose of a clock output is to synchronise upstream devices like CD transport on a S/PDIF type of connection, not a downstream DAC. It makes sure that incoming stream has the same frequency, so there will be no buffer under/overruns, in such case there is no need to use PLL after decoding S/PDIF signal. It is the most important part. The actual timing of reclocking is enforced by a clock on a DDC (or external input) in this case.I made a small change to my setup. I had been feeding the repeated ext clock signal out of the di24he to my streamer for a long while, almost from the beginning. This morning, I decided to use the unused output of my Afterdark Trifecta Eva clock. Sound is more fluid and smoother. And staging has taken a notch. This was predictable since jitter can only increase with the signal going through the 24. And it is likely that noise is already ultra-low at the output of the Afterdark.
In my setup, the di24he clock outputs will come in handy if I get an external clocked switch. In the mean time, I won't use it.
