sajunky
Gustard's clock synthesiser has some issues, measurements show high-frequency spurs, I remember one reviewer pointed it out. It is also not sure whether external synchronisation is implemented properly. It is not only one questionable feature for usability, streamer feature is in practice limited to Roon, otherwise it works unreliable. The same story with native DSD decoding.In my experience the external clock is one of those extremely divisive objects, in some systems it seems to give very positive results, greater dynamics, crazy details, but if the system is set up accurately, the electrical phase is verified and and ground connection well done, the The contribution of the external clock can become minimal and futile. I tested the Mutec Ref 10, Gustard C16 and C18 and other DIY or assembled clock 10Mhz. I'm not fully sure that this result can be repeatable in all our audio system.
Some members on the forum used this for questioning usability of external clocks in general (with the attitude that Gustard cannot be wrong), it is important to know that with other brand it can be completely different.
It is why I suggest to keep your Mutec and other clocks and try again with DI-24HE, attaching your R26 only by I2S (no external clock to Gustard). Keep in mind that you will be limited to the PCM playback, as Gustard do not support DSD autodetect over I2S connection.
Edit: I noticed response from @Jake2 only after writing this.
