FredA
- Dec 15, 2013
It does not mean all units will be that good but some should.Awesome work Fred... looks like the official spec of -110db @ 1hz was rather conservative indeed!
Fer sure. In an area where every extra -1db @ 1hz is hard won and priced accordingly, it's great to think they'll be somewhere in the -110-115db range, perhaps even consistently in the upper end of that range per the anecdotal comments from Beatechnik about Jays saying it's competitve with Cybershaft <-113/114db clocks.It does not mean all units will be that good but some should.
@gimmeheadroom I've found just the clock for you, this Cybershaft has four inputs each individually switchable between 50/75 ohms.I saw the comments but I can report even using a 50 ohm DI-20 WCLK into a Brooklyn DAC+ using a standard 75 ohm clock cable works and sounds pretty much indistinguishable from the internal clock. So I wouldn't spend money on a cable like that.
Rather, I ask again- no, I demand! - that consumer hifi manufacturers reject the non-standard 50 ohm clock setups and go 75 ohm like the pro audio world has done since the 1980s...
You sent me into fits of laughter. Same &##% thing I've had to deal with numerous times with the DI20. Of multiple noise issues this has exhibited; most being luckily fixed with a random change of DAC, this still issue still persists but for me it's with DSD. Usually when I press stop or do any navigation within a DSD track, is when I hear the ultra loud ear numbing squelch noise so loud I can feel it through the headphones. Once I had to go into recovery mode to give my ears a break. This thing is a curse and a blessing.Hello. I use the original di20 and was wondering if anyone else came across an issue I had. I was burning in a new headphone and my di20 randomly sent out a really loud ongoing beep to my r8, I had to volume down my amp and actually thought my headphones broke cause of how loud it was. Thankfully its fine but it was that loud since I heard it from another room. I then used AES and everything seems fine. I cant tell if its i2s or not since I always used i2s connections with my di20. I currently have the newest firmware for my r8 and 3.993 for the di20. Also, I use the popular Morion ocxo square wave.
Luckily I didn't have the headphones on when the loud beep started or I may have lost hearing, no joke. If anyone else had this issue please let me know.
https://cybershaft.shop/products/op...put-10mhz-master-clock?variant=41464326946991
My suggestion was a bit of a lighthearted one tbh given its extreme cost. But their approach is interesting.I am not sure how the switching between 50 and 75 Ohm works, as all the connectors are 50 Ohm. Maybe it is similar to the hybrid word clock output on my DI-20HE, that was converted internally to 75 Ohm but still has the 50 Ohm connector.
Presumably your USB or other digital cables came loose or had some microarching because it seems indicative of a lost signal. If not that, who knows if it was caused by the aforementioned codecs or cable length, and hopefully fixed now.
I have nothing to compare it to, but the performance of the LHY OCK-1 and Gustard C2 is excellent, the sound is much better than with the DI20HE internal clock.From what some have experienced, the LHY OCK-1 performs well for its price.
And one less linear power supply is helpful in my predicament.
So...
About to order a LHY OCK-1 from Beatechnik.
And probably a Gustard C2 to match.
Seems like very good choices. The c2 is rather expensive but worth it soundwise.Back then to my clock question.
Or more, to my clock solution.
Import duty and tax kicks in over NZ$1000. Hoping to keep under that, otherwise AfterDark, Cybershaft and Mutec become even more expensive.
And not really interested in a clock that costs more than my Dac.
If that's the case I'm probably better off buying a better Dac.
So...
Hi greetings !Lucky for you if you can import from China without doubling the price! I would like to try this clock but it would cost me at least 2X the price by the time various offices get their hands out of my pockets.
