gimmeheadroom
Hi greetings !
How is the LHY Clock so far ?
Best !
Hello
I'm sorry, I don't have it...at the time of that post there was European distributor. I plan to get one later. 2 or 3 guys here did already.
Hi greetings !
Best !
I have a hard time finding there powersupply in europe:For what it's worth LHY warn against buying from Aliexpress (i got mine from LHY though a little more expensive), as there's no authorized vendors on there, though I've disregarded that advice for one of their other items.
Ask them. They state that 5A for 12V so... You should probably get 4A, at least.I have a hard time finding there powersupply in europe:
https://www.beatechnik.com/product-page/lps80va
This says 80VA. If I choose 15V it will deliver 5.33A right?
They have European distributors now so you could just email them.I have a hard time finding there powersupply in europe:
Who is the European distributor?They have European distributors now so you could just email them.
its actually for my Chord TT2. Just wanna try and see if it can improveThey have European distributors now so you could just email them.
Personally I'm very against external power supplies. There's a healthy toroidal transformer in the LHY clock, if I get the LHY I'll use the internal power supply.
15x4=60VA =4A?Click on the specs tab of that page at the bottom. Shows specs for a range of voltages if not 15v. Looks like those 80va options all calculate to around 60va rather than 80va (not sure why), so the 15v would be around 5A.
Yep, typo!15x4=60VA =4A?
If this is true its perfect
Some background info: it’s the first external clock in my system. I heard about how an external clock makes changes to sound quality but most of them cost over USD1,000 like the Cybershaft, Mutec, Grimm. No budget to try these.Hello I am having my DI20 (non-HE) with me for a year. Keep following the post here and pleased to learn from the sharings.
Learnt the positive comment from some of you, I ordered a LHY OCK-1. Waiting for its arrival after the long Chinese holdiay, I'm lucky the unit will be sent from LHY 4 hours driving distance away from my place.
Will share my listening experience when got it connected.
OCK-1 arrived yesterday and I concur with the previous poster. For me sinewave sounds better, probably system synergy or due to BNC cable (Cybershaft semi rigid).
