Audio-GD DI-20
Sep 29, 2022 at 5:16 AM Post #4,141 of 5,353
They finally have European sources for the LHY. I'll pick one up when I get back, I'm away on business now.
I'm peeved they have only one square wave output. Later I'll write and see if they can build one with 2 75ohm and 1 50ohm outputs, all square wave.
Sep 29, 2022 at 5:19 AM Post #4,142 of 5,353
There's a good lesson there. At some point you have to start spending huge money for incremental gains.
The LHY build looks better than Aune. I would pass on the latter.
Reading the posts on the thread about the LHY, it seems more safe to buy it from Beatechnik.
I need to choose between 75 Ohm and 50 Ohm outputs.
I have only two devices in my setup with a 10 MHz input: the DI-20HE and EtherRegen. Furthermore, I'm planning to upgrade in the future to a DAC with a 10 MHz input.
Any advises for the output impedance that I should select for the LHY?
EDIT
@gimmeheadroom posted about this issue while I was writing my message.
Who is their European retailer?
Sep 29, 2022 at 5:21 AM Post #4,143 of 5,353
I see authorized European distributors on the beatechnik site. I can't buy from Singapore, it would cost me at least 2X.
Any advises for the output impedance that I should choose for the LHY?
if you're going with Audio-gd or consumer gear, 50 ohms all the way.
I have pro gear which is all 75 ohm, plus Audio-gd gear. That makes it a lot harder until I spring for the Mutec clock.
Sep 29, 2022 at 5:28 AM Post #4,144 of 5,353
I guess there's the Gustard C2 cable to the rescue if you put stock in their impedance matching claims. It certainly sounds good but is a bit spendy.
Sep 29, 2022 at 5:45 AM Post #4,146 of 5,353
Not that simple. F.i. the R8HE Mk2 will be 75 Ohm when you opt for the EC (external clock) option, which is user selectable via firmware. Also, the DI-20HE can be easily ordered with 75 Ohm.
Sep 29, 2022 at 6:43 AM Post #4,149 of 5,353
I have decided to go for the matrix spdif2, because Im concidering not selling my TT2, It sound so sweet, I can not give it up.
When I get the R8HE mk2 it will be connected to the I2S and the TT2 optical.
What do you guys think of this.....
What DDC could be a better option that has optical and I2S?....not interested in Singxer....denafrips?
Optical should work fine if the source is decent. The mkii redoes the timing entirely. Plus you will avoid ground loops.
Sep 29, 2022 at 6:48 AM Post #4,150 of 5,353
EDIT
They likely can do a mix of both.
Sep 29, 2022 at 6:48 AM Post #4,151 of 5,353
If I save 350euro(douk) for almost same performance I am happy. This means I will get R8HE mk2 sooner😊
@gimmeheadroom thanks!🙌
Sep 29, 2022 at 6:49 AM Post #4,152 of 5,353
Sep 29, 2022 at 7:20 AM Post #4,154 of 5,353
Yes, i would ask for it. Try also with ali. They sure can do it on Beatechnik.
Thanks. :thumbsup:
I sent a message to Beatechnik, asking if it's possible.
I will report their answer.
Sep 29, 2022 at 7:22 AM Post #4,155 of 5,353
