sajunky
5V can be found inside DAC. The best is to take from the power supply of the interface chip converting from LVDS (HDMI I2S signal lines) to the internal logic levels. It might be 3.3V, not 5V.If you say "the 5V power source", do you mean that this is already available somewhere in the DAC? If yes, where to look for it?
And about the resistor: what value and where would you put it?
Not that I will try anytime soon, just trying to understand...
Resistor value is not critical, 1k to 10k will do. If wires go outside the case (to the external switch), 10nF film cap can be added in parallel to the ground, it will prevent triggering false detection of a noise.
