Mine is also bullet proof doing USB=>I2S. If you're one to roll the dice on a $100 cable then
this is well within reason.
Alex @uptone sent me that link - looks like an unbranded DOXCO like the one in the TerminatorPlus.
If you like what you hear and want more, then swap in a
2008 Morion (I see 4 solder points)
Or offer Queen's_land something closer to $200 and see if he takes it ($300+ is stupid).
@DecentLevi
whatever is your last ethernet connection before reaching the DI20 (I suppose your laptop) will instead connect to the 100mbit B port on the etherregen.
On the other end is an A bank of gigabit ports that you'd connect back to your router. For many this would be an extra hop but I'm already using a
$17 Trendnet switch that I plan to swap out, and someday I'll get a pair of SFP tranceivers and isolate my switch galvanically, but I'll need to cut one end off a
35m+ run and snake that through small holes in/around the home, then re-terminate.
