BostonBeemah
I would give it a shot but mine won't connect to my computer after the past beta android update that essentially bricked my device lol
Nice work though!
Nice work though!
Thank you for this, took alittle while but I got it figured out and am on 0.1.8, gonna test it out the next few daysI decided to publish my patched AudezeHQ.exe files that point to my own server with the latest versions. It should work as fine as with Audeze's server, but I have to warn everyone that everything you do, you do only at your own risk.
What patch does?
Steps:Code:Replaces this: https://audeze-penrose.s3.amazonaws.com/AudezePenroseFW.xml ... by this: https://krasovs.ky/./././././././././././././FW_V_0_1_7.xml ... or this: https://krasovs.ky/./././././././././././././FW_V_0_1_8.xml /././. is just a filler to has the same string length.
- Choose version you want to update.
- Replace original AudezeHQ.exe (path: C:\Program Files (x86)\Audeze\AudezeHQ) by patched one.
- Launch it as usually, go to settings, click "Update firmware".
Code:AudezeHQ.exe (0.1.7) SHA1 hashsum: f3e4a897d167fe0ae7593c6dbf75157ab26ad11b AudezeHQ.exe (0.1.8) SHA1 hashsum: 26c76b6636a9013e83e26ef6610e58f731e55e02
Nice to hear! Since 0.1.5 I only noticed mic improvements and BT only mode which can be achieved by holding mode switching button.am on 0.1.8
You device was bricked by broken Android updater AFAIK PC updater worked well with both 0.1.7 and 0.1.8.the past beta android update that essentially bricked my device
If I keep the mode switching button pressed, pairing starts. Where am i wrong?Nice to hear! Since 0.1.5 I only noticed mic improvements and BT only mode which can be achieved by holding mode switching button.
Well, I also noticed this. But I think it's just a bug or sorta. Because it disconnects my PC and keeps only BT connection after this phrase.If I keep the mode switching button pressed, pairing starts. Where am i wrong?
In my case full working day (a lot of music, some evening games, volume 60-70%, 10-12h). In my opinion battery percentage is completely broken, I just leave them at night at charge (at pretty lowpowered PC USB port).What are your experiences with battery life after a few months of use? I'm feeling like while using the headset on my Windows 10 PC I only get 3 - 4 hours of use before the "LOW BATTERY" message is heard and I'm forced to wear them as a wired headset plugged in to keep them going.
Is it even possible to easily swap the batteries out in the future?
While I am totally agree with you, I have published this while keeping in mind that this is the enthusiast forum. I hope everyone who installed it (there are only few of them according to my logs) are understanding all the risks.We'd appreciate it if you would allow the process to unfold as it should, with public release AFTER beta tests have proven the updates to be safe for consumption.
We love the enthusiasm!While I am totally agree with you, I have published this while keeping in mind that this is the enthusiast forum. I hope everyone who installed it (there are only few of them according to my logs) are understanding all the risks.
I won't publish newer patched versions, but will continue to at least monitor newer betas, hope it's okay for you.
Gotta say, the geekria head band cushion thingy made it look a whole lot better than the dekoni nuggets, goes with the grey cups too. I hope audeze comes out with stickers or something to cover the ugly green logo on the headband sides, that's my only complaint so far lol
