Wirelessly as in with the dongle or via bluetooth? I'm trying to find out how discord will sound if you are wirelessly connected to a console and hooked up via Bluetooth to a PC. If the PC Bluetooth audio is lackluster I wanted to know if you are actually able to use wireless to console and 3.5 to PCNot sure his username on this board but we just did a test on Discord together (both wireless Penrose) and confirmed we both sound good. We just used a default discord voice channel set at the normal 64 bitrate. Both of us had default user profile settings, but max mic volume, which I use for any headset.
Going to test some more with my friends' setting because now I'm extra confused. Mic sounds very good.
Audeze Penrose X and Penrose
- Thread starter Audeze
Scratchansniff
How soon till penrose x finally ships?We are shipping all the orders. Most should go out the next few days. Transit times change depending on carrier and customs clearance.
That might explain why it sounds bad, that sounds super low.Yeah you can edit a voice channel's bitrate if you have permission to. The default is 64.
Scratchansniff
I could be mistaken but it’s average I think.That might explain why it sounds bad, that sounds super low.
Wireless we both sounded good in Discord. I'll try to test the BT + Wireless combo you mentioned.
Awesome that would be very much appreciated! Also if it does not sound good via Bluetooth would you be willing to try out having it play wirelessly to the console with the 3.5 mm Jack hooked up to the PC direct? Thanks againWireless we both sounded good in Discord. I'll try to test the BT + Wireless combo you mentioned.
WhiteHartMart
Can anyone who is using these on PS5 comment on the max volume please (apologies if it's already been mentioned). I've got a USB DAC currently on PS5 and output volume is lower than when using the Optical connection on PS4 - have read the USB output volume on PS4/5 is low so wondered how this affects the Penrose USB dongle setup?
I'd already like to know how loud these go, when I'm listening to music I like it LOUDCan anyone who is using these on PS5 comment on the max volume please (apologies if it's already been mentioned). I've got a USB DAC currently on PS5 and output volume is lower than when using the Optical connection on PS4 - have read the USB output volume on PS4/5 is low so wondered how this affects the Penrose USB dongle setup?
- Mar 20, 2010
I haven't done a comparison since I pretty much just moved to the X for testing since it's the more recent firmware. The regular one was packed up to ship back as soon as I get a label.@Mad Lust Envy you mentioned that you have the penrose X already, have you noticed any difference between the X and your pre production regular penrose? I’m more specifically wondering if there’s any difference in the wireless connection between the two, like the range or any difference in signal integrity. I’m assuming they’re identical but I thought I’d ask anyway since you’re the only on who has tested both so far.
In any case, they should be identical with the only difference being the usb stick that has the Xbox switch on it. The difference is the Xbox support and color.
SkullHydra
I guess this will finally clear up the fact that the X is just a better version [Despite color], and works with everything including PlayStation.I haven't done a comparison since I pretty much just moved to the X for testing since it's the more recent firmware. The regular one was packed up to ship back as soon as I get a label.
Scratchansniff
Aren’t you limited though if you use it on PlayStation? I mean connection wise.I guess this will finally clear up the fact that the X is just a better version [Despite color], and works with everything including PlayStation.
SkullHydra
The only limit would be no party chat, but that's a problem with both versions. The X doesn't have any decreased functionality from the standard Penrose.Aren’t you limited though if you use it on PlayStation? I mean connection wise.
Seems like a lot of USA foks are receiving their orders. No reviews, but it seems the consensus is that they sound pretty good.
Scratchansniff
Oh so the party chat will only work on their own platforms ie penrose x on Xbox etcThe only limit would be no party chat, but that's a problem with both versions. The X doesn't have any decreased functionality from the standard Penrose.
Total: 16 (members: 0, guests: 16)
