When you plug them in the charger is it suppose to blink red? When I turn them on it shows yellow/green. It's my first planar headset. Love it so far.
Audeze Penrose X and Penrose
- Thread starter Audeze
I ordered 11/5, no notification yet
Sorry, I went back and checked, it was placed 10/28
Ordered from the future, eh? I'll have to try that one out some timeSorry, I went back and checked, it was placed 11/28
Thanks for the update, I'm sure mine will get processed soon enough.
LoneSyndal
Had the Penrose quite early and thoroughly enjoyed them. The microphone recv from other users seems to be hit or miss, but when I listen to my own recording sounds perfectly fine. This leads me to believe Discord's voip is probably doing some other processing that causes this issue. To some other users, sounds perfectly fine.
Also noticed that the Gel Pads for the Mobius are no longer available. Would these be restocked at a later date, @Audeze ?
Yes that indicates it's charging.
Green light means you're connected wirelessly. A yellow light in between means low battery.
Apex Legends on PC sounds accurate and lovely and this is coming from a PC37x which already sounded good.
Has hifiheadphones.co.uk sent anyone's order yet?
astrothundr
@Mad Lust Envy you mentioned that you have the penrose X already, have you noticed any difference between the X and your pre production regular penrose? I’m more specifically wondering if there’s any difference in the wireless connection between the two, like the range or any difference in signal integrity. I’m assuming they’re identical but I thought I’d ask anyway since you’re the only on who has tested both so far.
Androidisgimp
No. I ordered in July. No word whether they have left the Audeze yet either
I have been unable to find the answer to this question about any of the penrose models. I understand that the usb dongle will be used to send audio to the headphones wirelessly. That said, my question is this. I want to use discord on PC, game on console. Currently using a cheaper BT/wireless gaming headset, the audio I receive from the PC (using BT) is horrendous and so is the mic quality. I understand the bluetooth standard is lower on my older headphones. Is the quality acceptable now via BT to discord on PC while using wireless console audio? If not, Can I use the wireless audio and then hook up a 3.5mm to my PC and use them simultaneously? I only ask because when I hook up my current headset via 3.5 jack it cuts out the audio from the console. Thanks in advance!
Scratchansniff
So it’s safer than the headset stand to achieve this do you think?. I won’t put it on the headset stand if their is a risk of damage.That's all it is. It basically slowly loosens up the clamping force the headphones. Since pillows are soft, you don't have to worry about damaging the headphones.
Scratchansniff
When you say set the bitrate do you mean on discord?Not sure his username on this board but we just did a test on Discord together (both wireless Penrose) and confirmed we both sound good. We just used a default discord voice channel set at the normal 64 bitrate. Both of us had default user profile settings, but max mic volume, which I use for any headset.
Going to test some more with my friends' setting because now I'm extra confused. Mic sounds very good.
We are shipping all the orders. Most should go out the next few days. Transit times change depending on carrier and customs clearance.No. I ordered in July. No word whether they have left the Audeze yet either
Stay updated on Audeze at their sponsor profile on Head-Fi.
waltdisneypixar
Do you know anything about Spain availability?
Yeah you can edit a voice channel's bitrate if you have permission to. The default is 64.
Total: 9 (members: 0, guests: 9)
